Toymods » Tech & Conversions » throttle stop screw???
chadix24_7
cebu city, philippines
throttle stop screw??? Fri, 24 June 2005 17:00 Go to next message
what's it for?
how can it be adjusted properly?
engine is a 4age 16v tvis redtop.
please explain clearer for i am a newbie. Very Happy
thanks and more hp. Smile
chadix24_7
Re: throttle stop screw??? Sat, 25 June 2005 01:33 Go to previous messageGo to next message
anyone? Sad
Celica_John
Re: throttle stop screw??? Sat, 25 June 2005 02:13 Go to previous messageGo to next message
isn't this to set the throttle position sensor? is that the one you're talking about? in which case you'd use a service manual and a feeler guage to set it accordingly
SPRINTAH!
Re: throttle stop screw??? Sat, 25 June 2005 02:26 Go to previous messageGo to next message
i'm pretty sure you set it up so its just touching when the throttle is totally off. i think it is to stop the butterfly jamming shut inside the TB. there is a separate idle circuit that bypasses the butterfly so its not for idle control
chadix24_7
Re: throttle stop screw??? Sat, 25 June 2005 03:35 Go to previous messageGo to next message
SPRINTAH! wrote on Sat, 25 June 2005 12:26
my not so good with efi engines mechanic just screwed with it thinking it's for idle. now i would undo the crap he has done.
how would you adjust this thing? turn it a little just to open the throttle a little bit? what about the in conjuction with the tps? set it back to specs?
cheers! Very Happy
Bobski
Re: throttle stop screw??? Sat, 25 June 2005 05:26 Go to previous messageGo to next message
adjust it so that it just touches then give it about another 1/4 turn just so the butterfly doesent stick....
then adjust tps accordingly to settings in tech section
Adam
Bodgie Luigi
May 2005
Re: throttle stop screw??? Sat, 25 June 2005 07:14 Go to previous messageGo to next message
Kumusta
My manual says you should have zero clearance when the valve is fully closed. As suggested earlier it may just be there to prevent the throttle sticking shut.
Should have little affect on idle speed until it is open too far for the ECU to adjust with the ISC valve.
chadix24_7
Re: throttle stop screw??? Sat, 25 June 2005 13:40 Go to previous message
Bodgie Luigi wrote on Sat, 25 June 2005 17:14
Kumusta
kumusta too. Surprised
guys thanks so much for the help now i know how to adjust it. going to do it asap. more hp! Very Happy
Previous Topic:T-series lsd
Next Topic:Fitting SC14 to AW11gze
Current Time: Thu Nov 19 06:38:35 UTC 2026
Total time taken to generate the page: 0.0050821304321289 seconds
