Toymods » Tech & Conversions » Quick Plumback BOV question
Classique71
Colac, Victoria
Quick Plumback BOV question Sun, 26 June 2005 06:40 Go to next message
Just a quickie
having never set up a bov before - i need a little help
the vaccum line off the top of the bov ( in my case turbosmart plumbback ) has to be tapped into the intlet plenum
Is it best to use a dedicated line for it - or can the vaccum be tapped off off another vaccum line off the plenum ..I have a small dedicated one at the back of the plenum - though at a guess the pipe diameter seems larger than the one on the bov. I probnably could reduce it but not sure which way to head?
any help appreciated as normal
ke382TG
Re: Quick Plumback BOV question Sun, 26 June 2005 06:56 Go to previous messageGo to next message
Many people do tap them into an existing line. BUT, I have previously had a BOV tapped into the boost gauge line and it made the boost gauge flicker spastically when the BOV was opening and closing so I thought it may actually not be a good idea to have the vaccuum line for the BOV plumb into anything that needs to read an accurate boost/vaccuum.
The golden rule though is to keep the line as short as you can (being practical about it of course).
I would use the dedicated point you mentioned at the back of the plenum and use a commonly available reducer Smile
Cheers.
Classique71
Colac, Victoria
Re: Quick Plumback BOV question Sun, 26 June 2005 07:12 Go to previous message
Cheers - jjst took the plug off the dedicated point - looks like toyota may have had this in mind for either map sensor ecu or BOV - just never got around to it ..
Another little mystery ive found on the gt4 with no logical explaination to be seen ( like why have clips under arches and along doors that just happen to be perfect for rear mounting the battery cables )
Seems like alot of these things for the rallycars may have filtered thru to the road goers
Previous Topic:Balancing Flywheels (warning: massive pics)
Next Topic:18R-G cams, which are the best?
Current Time: Fri Oct 23 10:27:36 UTC 2026
Total time taken to generate the page: 0.0035018920898438 seconds
