Classifieds » Parts Wanted » Top-of-Door Moldings from Series I TA22 Wanted
Grant
Newcastle, NSW, Australia
Top-of-Door Moldings from Series I TA22 Wanted Thu, 05 December 2002 20:56 Go to next message
I'm in need of a set of s/steel door moldings from an early series TA22. The ones I am referring to run along the top of the door and 1/4 window. They screw to the inner edge of the door and also hold the window seal.
Grant
[Updated on: Sun, 15 December 2002 20:59]
sleeka
Sunshine Coast
Re: Top-of-Door Mouldings from Series I TA22 Wanted Sat, 14 December 2002 01:02 Go to previous messageGo to next message
Not sure if this helps but im wrecking a ta22 1974 built on the 10th month its a complete car so...
silverfox
Cabooture QLD
Re: Top-of-Door Mouldings from Series I TA22 Wanted Sat, 14 December 2002 14:35 Go to previous messageGo to next message
hey sleeka you wouldn't happen to have anygood door / window rubbers would ya , any good rubbers at all , cause i need some for my TA22 but i don't knwo where to get them
sleeka
Sunshine Coast
Re: Top-of-Door Mouldings from Series I TA22 Wanted Sat, 14 December 2002 22:45 Go to previous messageGo to next message
Ok,
i would never sell you any rubbers from any celica made in the 70's not worth it they are usually stuffed. but if you go to clark rubber you can usually find something that fits failing that you can but i complete rubber kit for around 200.00ish dollars which is every rubber was ever put on the celica and its all new. The name is called rarespares, not sure how you would get in contact with them try ringing around maybe call a windscreen repair company because they use rarespares window rubbers and see if they give you a contact.
tah tah.
silverfox
Cabooture QLD
Re: Top-of-Door Mouldings from Series I TA22 Wanted Sun, 15 December 2002 01:14 Go to previous messageGo to next message
Thanks Sleeka
Hey Grant , i may have some , they're off a 73 TA22 , they have some slight surface rust , and in general need a good clean
Grant
Re: Top-of-Door Mouldings from Series I TA22 Wanted Sun, 15 December 2002 20:58 Go to previous messageGo to next message
Just to clarify, the type I am after do not have the plastic caps fitted to each end of the molding. The ones fitted to the early TA22 were folded at the end.
Grant
thetoyman75
Club President
Re: Top-of-Door Moldings from Series I TA22 Wanted Sun, 15 December 2002 23:44 Go to previous messageGo to next message
Grant,
Will check on the 72 model tonight mate pretty sure they are all there just wanna make sure they are in servicable condition.
Grant
Re: Top-of-Door Moldings from Series I TA22 Wanted Mon, 16 December 2002 00:16 Go to previous messageGo to next message
THANKS ROD.
sleeka
Sunshine Coast
Re: Top-of-Door Moldings from Series I TA22 Wanted Mon, 16 December 2002 08:31 Go to previous messageGo to next message
Ok look this is all i can say i have the top door moldings from a ta22 celica still on the car in good condition no plactic cap stuff, its folded over at the ends.
does that help?
thetoyman75
Club President
icon10.gif  Re: Top-of-Door Moldings from Series I TA22 Wanted Mon, 16 December 2002 12:52 Go to previous messageGo to next message
Grant,
Mate checked em out and I have 3 of the 4 here. They are in need of a good polish but have no major damage. Polishing will more than likely reveal minor dents tho. (I must have polished a dozen of each strip before I got 4 good ones for my car Sad )
The drivers door is a late model type but the rear 2 and passenger door are there. Removing them will be a PITA as those mounting screws generaly rust. I have the Dremel here tho so can grind the offending screw heads off if necessary Smile
If your coming down this way at all your welcome to drop out for a look otherwise I'll remove em for you but you'll have to give me till after Xmas. I am flat out at the moment Sad
let me know Smile I can take a pic but it will never show there true condition. (bloody camera's) Price also depends on who removes em Smile
Regards,
Rod.
Grant
Re: Top-of-Door Moldings from Series I TA22 Wanted Sun, 29 December 2002 21:56 Go to previous message
Sleeka,
Did you get my email? Haven't heard back from you; maybe your on holidays?
Previous Topic:wtb: nock sensor 7mgte
Next Topic:4AGZE COMPUTER
Current Time: Sat Nov 21 06:56:07 UTC 2026
Total time taken to generate the page: 0.0046839714050293 seconds
