Toymods » Tech & Conversions » 1JZ Timing problem
mz21_shiznac
Bunbury, W.A.
January 2005
1JZ Timing problem Sun, 26 June 2005 10:52 Go to next message
Okay may be a bit of a tricky one but we will see...
The timing belt tensioner pulley has a pressurised little cylinder that tensions the pulley, and seems to have a huge amount of pressure. Or it is stuffed. I can get it to move onley in a vice. I was just wondering if anyone would know if these are meant to have a large amount of pressure or if you are supposed to move it by hand. I thought I would check this before putting it back on to make sure it is okay or if it isn't. I'm basically at the cost of an engine here, so I'm trying to be careful.
sideshow
Re: 1JZ Timing problem Sun, 26 June 2005 12:01 Go to previous messageGo to next message
tes vicer is only way u will move it
this is normal
u need a tiny allen key or somehting to locate it in closed position then fit it to engine
mz21_shiznac
Bunbury, W.A.
January 2005
Re: 1JZ Timing problem Sun, 26 June 2005 12:49 Go to previous messageGo to next message
Ah cool man just as I thought, thanks alot, I'll ba able to drive it again Surprised
wilbo666
Re: 1JZ Timing problem Mon, 27 June 2005 02:19 Go to previous messageGo to next message
yep sideshow is right, the method to install the tensioner is to put it in a vice, and then use an allan key to hold it in the down position. Install it and the timing belt onto the engine, and then remove the allan key. Smile
If you can move it by leaning on it against a wall/floor etc it is stuffed.
ChuckLandwehr
Re: 1JZ Timing problem Mon, 27 June 2005 03:05 Go to previous messageGo to next message
Just a word of caution:::,"use small increments when turnining the vice handle" It may take 5 minutes to compress this way, but you will not stuff the tensioner.
cheers Chuck.
mz21_shiznac
Bunbury, W.A.
January 2005
Re: 1JZ Timing problem Mon, 27 June 2005 10:55 Go to previous message
Ok cool cheers will take it easy then Smile, yay I haven't driven it in 5 weeks. I miss driving it.
Previous Topic:SW20 MR2 3SGE N/A into 162SX Celica
Next Topic:chasing down a brake master cylinder 4 a ra23
Current Time: Fri Nov 20 20:52:00 UTC 2026
Total time taken to generate the page: 0.02907395362854 seconds
