Toymods » Tech & Conversions » ae86 4age sump removal
86DRFT
Rockhampton QLD
ae86 4age sump removal Sun, 26 June 2005 13:16 Go to next message
The sump on my rwd bigport 4age is leaking. Is it possible to remove the sump without removing the engine? i dont want to break the seal to find out that it's stuck. Rolling Eyes I'm guessing it might foul the strainer, but it should be ok if i undo the strainer right?
thanks in advance Smile
4agte
Toronto, Downtown
Re: ae86 4age sump removal Sun, 26 June 2005 13:19 Go to previous messageGo to next message
if it was an aw11 i would say yes but im unsure with the ae86
ae86trueno
Re: ae86 4age sump removal Sun, 26 June 2005 22:43 Go to previous messageGo to next message
i have taken the sump off the 4ag while still in the car to fix the oil pump, Strainer doesnt get in the way, you just have to remove the 2 lower engine to gearbox mounts.
Ben.
ke35 - 4AGZE
Re: ae86 4age sump removal Sun, 26 June 2005 23:12 Go to previous messageGo to next message
i removed mine without removing the engine and without undoing mounts,
once i had it unbolted and broke the seal, i turned it and dropped it down.
it was easy in the end, i put it off for a while because i thought i would have to remove the whole engine but in the end it was easy!! Very Happy
Steve-AE86
Ademelaide, SA
Re: ae86 4age sump removal Sun, 26 June 2005 23:14 Go to previous messageGo to next message
makes it easier to undo the engine mounts, and jack up the engine as well..
if you've got power steering, i wouldn't bother doing it in-car. took me all day once.. Confused
ae86slaver
Re: ae86 4age sump removal Mon, 27 June 2005 05:50 Go to previous messageGo to next message
easy
i did it in the car, without undoing any engine mount nuts etc.
a good idea would be to have rachet ring spanners, uni joint extensions and a helping hand. The strainer might get in the way, just manouvre is out
takai
Re: ae86 4age sump removal Mon, 27 June 2005 06:08 Go to previous messageGo to next message
Bah, just drop the crossmember and hold the engine up by the gearbox stays Smile
86DRFT
Rockhampton QLD
Re: ae86 4age sump removal Mon, 27 June 2005 07:18 Go to previous message
thanks guys, i got the thing off. one of the weird things i found was that the engine-gearbox mounts werent bolted to the geabox! Confused
Previous Topic:is it possible to do a HID conversion for a st162?
Next Topic:3TGTE thermostat housing neck
Current Time: Wed Nov 25 20:39:19 UTC 2026
Total time taken to generate the page: 0.024631977081299 seconds
