Toymods » Tech & Conversions » 3rd Gen 1G-GTE into USDM MA70
AE_Racer
FL, USA
June 2005
3rd Gen 1G-GTE into USDM MA70 Sun, 26 June 2005 17:08 Go to next message
Im in the process of swapping a 92 1G-GTE out of a GA70 into my US MA70..I have it mounted now im just getting into the wiring...Just wondering if anyone knew of anybody else that has done this?
edit:forgot to add, my car is an 89..also, does this motor have a boost sensor? cause i did not recieve one with my motor set..
[Updated on: Sun, 26 June 2005 21:39]
lumpy
Adelaide, SA
Re: 3rd Gen 1G-GTE into USDM MA70 Mon, 27 June 2005 03:30 Go to previous messageGo to next message
You'll probably find very few people have done this in Aus because the 1g-gte torque output is pretty underwhelming for a heavy car like the MA70. Better options would be 7M-GTE, 1JZ-GTE, 2JZ-GTE or V8 goodness with a 1UZ-FE.
Prepare for disappointment.
Re: 3rd Gen 1G-GTE into USDM MA70 Mon, 27 June 2005 04:28 Go to previous messageGo to next message
1g-gte use AFM sensors, not MAP (or so i've found) so there's no boost sensor to look out for.
There's a few 1g-gte install guides into celica's around here <http://www.toymods.org.au/tech.html> but you'll have to sort out plumbing of air-con/power-steer lines yourself as it's an unfamiliar swap.
(edited to fix acronym)
[Updated on: Mon, 27 June 2005 10:31]
HyDrA
Adelaide, SA
Re: 3rd Gen 1G-GTE into USDM MA70 Mon, 27 June 2005 10:06 Go to previous messageGo to next message
Actually, it has a vane style AFM.
When it reaches the maximum opening of the AFM the "boost cut" is triggered, seems to last forever but it might just be 1 second or so Smile
AE_Racer
FL, USA
June 2005
Re: 3rd Gen 1G-GTE into USDM MA70 Mon, 27 June 2005 18:44 Go to previous message
lumpy wrote on Sun, 26 June 2005 23:30
I know all about the powerloss etc..I have my reasons for the swap..Car came standard with a 7MGTE, tired of head issues..Just wanted something different, and I could sell my 7MGTE with rodknock for the amount of a 1G-GTE swap, so I had to spend no money (cause i have none)..1JZ, 2JZ etc are way too expensive over here..Either way thechuckster, i knew about the AFM part, I just wasnt sure if it had a boost sensor or not, thanks for the info!
Previous Topic:Camber tops noise
Next Topic:4age out of what??
Current Time: Fri Nov 20 18:53:49 UTC 2026
Total time taken to generate the page: 0.0060560703277588 seconds
