Classifieds » Engines, Accessories and other Mechanicals » F Series parts , LSD , 4.1 , 3.9 Gearing , mounts etc .
improvedae86
F Series parts , LSD , 4.1 , 3.9 Gearing , mounts etc . Mon, 27 June 2005 05:54 Go to next message
Ok since going to irs i don't have any need for the following parts
1 x MX13 diff housing , with axles and a box with new wheel bearings seals etc , also TRX 280mm disc with internal handbrake and alloy cailper mount , caliper etc . Which can be redrilled to fit the MX13 housing with the removal of the 3mm spacer between the bearing and axle end to correctly align the disc . Or you could maybe use the normal RT conversion etc to fit into a ae86 etc .
1 X F series live axle center , taken apart for inspection , perfect 3.9 gear set . New bearings , open center .
1 X F series , MA61 irs diff unit complete with 4.1 gearing and working tight LSD .
1 X S series housing , without spring perches , might be usefull for converting the MX13 to AE86 etc
1 X H190 nissan housing with a stuffed diff housing center plate , has adjustable AE86 mounting postions and adjustable shock mount locations , mounting points also for aus spec handbrake to TRX rear brakes , good for cutting all the mounts off .
4 X Sets of lazer cut mounts , adjustable postioning , antiroll bar mount {good for T series conversion}, complete for any diff into AE86 , width for housing has been cut at 60mm so can be made bigger if needed to fit any type of diff , also one AE86 diff jig onloan atm .
Need this stuff gone to make room , make any offer on the lot or parts .
http://forums.toymods.org.au/index.php?t=getfile&id=12847
Attachment: Diff Stuff.JPG
(Size: 70.11KB, Downloaded 271 time(s))
ae86slaver
Re: F Series parts , LSD , 4.1 , 3.9 Gearing , mounts etc . Mon, 27 June 2005 05:58 Go to previous messageGo to next message
got any stock sway bar mounts? if so, grinded and sent to Sydney?
Henn
Rosanna, Melb
Re: F Series parts , LSD , 4.1 , 3.9 Gearing , mounts etc . Mon, 27 June 2005 07:29 Go to previous messageGo to next message
Interested in the 4.1 F ratio. Or possibly the centre too.
Oh and I want that diff jig, I can collect.... wait a minute I already have.
Hen
improvedae86
Re: F Series parts , LSD , 4.1 , 3.9 Gearing , mounts etc . Mon, 27 June 2005 11:02 Go to previous messageGo to next message
Henn wrote on Mon, 27 June 2005 03:29
Hen
Your a drifter , come on your going to need a spare center and gearing
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: F Series parts , LSD , 4.1 , 3.9 Gearing , mounts etc . Mon, 27 June 2005 13:36 Go to previous messageGo to next message
PM Sent
improvedae86
Re: F Series parts , LSD , 4.1 , 3.9 Gearing , mounts etc . Tue, 28 June 2005 08:15 Go to previous messageGo to next message
Right who is first to place a bid ?
ViPeR_NiPPleX
VIC, Sth Frankston.
Re: F Series parts , LSD , 4.1 , 3.9 Gearing , mounts etc . Tue, 28 June 2005 10:30 Go to previous messageGo to next message
Hmm, i'll have to take a shot I guess....
$250 for the ma61 diff?? Confused
improvedae86
Re: F Series parts , LSD , 4.1 , 3.9 Gearing , mounts etc . Wed, 29 June 2005 07:07 Go to previous messageGo to next message
Looks like its sold to you Jimmy
ae86slaver
Re: F Series parts , LSD , 4.1 , 3.9 Gearing , mounts etc . Wed, 29 June 2005 07:51 Go to previous messageGo to next message
still after a word on sway bar mount availability?
improvedae86
Re: F Series parts , LSD , 4.1 , 3.9 Gearing , mounts etc . Wed, 29 June 2005 23:19 Go to previous messageGo to next message
Look at the picture at the bottom , the laser cut mount third from the right , that a roll bar mount cut out it just needs bending with two 90' . I didn't bend them because if you have a larger custom bar and a large diff center the roll bar clearance need to be more . I would prefer to sell all the mounts as one , but if no interest will sell the mounts individually .
V8_MA61
Re: F Series parts , LSD , 4.1 , 3.9 Gearing , mounts etc . Thu, 30 June 2005 11:35 Go to previous messageGo to next message
for much for the mx13 diff? Are these similar width and mounts to a ms85 crown?
improvedae86
Re: F Series parts , LSD , 4.1 , 3.9 Gearing , mounts etc . Sun, 03 July 2005 08:26 Go to previous message
v8ma61 , no idea , might have to ask so crown people man .
LSD 4.1 Sold
Previous Topic:CA18DET - AE86 conversion
Next Topic:4age parts for sale
Current Time: Sun Oct 25 12:21:27 UTC 2026
Total time taken to generate the page: 0.0048680305480957 seconds
