Toymods » Tech & Conversions » Camber tops noise
J-AE86
Camber tops noise Mon, 27 June 2005 11:37 Go to next message
i just installed camber tops, and now when i turn i can hear the spring move ? i have coilovers, and when i go over bumps it makes a little clunk noise, and with normal tops before it never did that, what could be the noise coming from ?
ST204R
Re: Camber tops noise Mon, 27 June 2005 12:09 Go to previous messageGo to next message
have you tightened the bolts down? Very Happy
did this to one of my cars, took me a week to figure it out. Laughing
ae95
Re: Camber tops noise Mon, 27 June 2005 12:14 Go to previous messageGo to next message
could be top hat binding on the bottom of the camber top
GTV Trueno
NSW - Coffs Harbour.
Re: Camber tops noise Mon, 27 June 2005 13:19 Go to previous messageGo to next message
If the strut top bolts arn't tight enough it well cause the coilover to unload when you go over bumps.
Cause you used standard strut tops on your coilover set-up the top hat is designed to slip over the strut sleeve you need to get new tophats and get them drilled so they sit on the part that the bottom section of the standard strut top locks into or you could get a spacer engineered that sits ontop of this same part and use your exsisting tophats. You will have to make sure the spacer is the correct height so that you can do the bolt on top up tight and there is no play when you pull up or push down on the cambertop. You may need a spacer also with new tophats, you may be able to fix your problem using washers.
ae86drift
sydney.au
Re: Camber tops noise Mon, 27 June 2005 13:45 Go to previous messageGo to next message
mine does this
but only when im stationary
Suprspt
June 2005
Re: Camber tops noise Mon, 27 June 2005 13:53 Go to previous messageGo to next message
Do the camber tops run spherical bearings by any chance? And do the spring hats mate properly into it?
M.W.P.
Rocky Mountains, Canada
Re: Camber tops noise Mon, 27 June 2005 17:23 Go to previous messageGo to next message
What camber tops?
I had to do some modifications to my spring hats and make spacers to get my Koni inserts, T3 tops and Noltec hats to work properly.
joyride
fairfield NSW
Re: Camber tops noise Mon, 27 June 2005 22:59 Go to previous message
cusco camber tops.
it was previously mine but now johnny has them.
they never did that on mine johnny..? wtf did u do mate? lol
Previous Topic:1ggze injector plugs
Next Topic:3rd Gen 1G-GTE into USDM MA70
Current Time: Fri Nov 20 19:43:05 UTC 2026
Total time taken to generate the page: 0.13126611709595 seconds
