Toymods » Tech & Conversions » What to do guys
badboybubby
On Probation
What to do guys Mon, 27 June 2005 22:53 Go to next message
After pulling the 1GGTE apart to do the head gasket I took the head to be machined and have been told its warped 10,000 on the right hand(turbo) side Mad any suggestions on what to do is it worth worrying about Crying or Very Sad
[Updated on: Mon, 27 June 2005 22:54]
EVOSTi
cambo
      no
Re: What to do guys Tue, 28 June 2005 00:43 Go to previous messageGo to next message
it will either have to be straightened or you have to get a new head. if you just machine it flat the compression ratio will be different in each cylinder.
[Updated on: Tue, 28 June 2005 00:45]
Re: What to do guys Tue, 28 June 2005 02:36 Go to previous messageGo to next message
10 thou is 0.25mm
you can work out the max change in compression ratio by using the size of the motor/cylinder etc...
at a total rough guess...
1GG = 6cyl 2L = 333ml/cyl
(very rough) combustion chamber volume = 42mls
thus CR = (333+42)/42 = 8.93:1
bore = ?? 80mm?
volume of change for 10 thou = Pi * 4^2 * 0.025 = 1.25mls
new CCV = 40.75mls
new CR = (333+40.75)/40.75 = 9.17:1
so a change of 0.24:1
anyhoo, thats my rough guesstimate on it Wink for 1G:
10 thou skim = approx 0.25 CR change.
Re: What to do guys Tue, 28 June 2005 02:37 Go to previous messageGo to next message
badboybubby wrote on Tue, 28 June 2005 06:53
its warped 10,000
FYI its '10 thou' or '10 x 1/1000 of an inch', or 0.01"
Re: What to do guys Tue, 28 June 2005 02:39 Go to previous messageGo to next message
Stu, bore is 75mm, stroke is 75mm.
And if you shave 0.25mm, just use a 0.25mm thicker gasket to bring it back to stock.
But if its only 0.25CR change, thats nothing, you'll like the extra torque.
badboybubby
On Probation
Re: What to do guys Tue, 28 June 2005 02:58 Go to previous message
Thanks ppl its 10 thou is it woth getting any work done to it while its in the shop ?
[Updated on: Tue, 28 June 2005 04:09]
Previous Topic:KE1x Pedal Box
Next Topic:engine weights?
Current Time: Fri Nov 20 21:45:45 UTC 2026
Total time taken to generate the page: 0.0040578842163086 seconds
