Classifieds » Cars For Sale & Wanted » Cordia Turbo Cheap
Wildsupra
Cordia Turbo Cheap Tue, 28 June 2005 10:20 Go to next message
selling for a friend.
1986 GSR Cordia turbo
5 Speed Manual
Stock engine
Immaculate interior
Paint faded, and a couple of dents. Car still looks tidy
Good tyres
3 months rego
immobiliser
Car is running but not properly, it idles but wont seem to rev at all. Maybe dodgy Tps or knock sensor???
Selling as is $1400
Matty
bunkyT18
Pilbara
Re: Cordia Turbo Cheap Wed, 29 June 2005 04:40 Go to previous messageGo to next message
I'm not interested in buying the car but I can offer some advice on why it may not be revving properly. Check all your vacum lines and the 'one way valves' also your vacum advance on the distributor.
DragonCypher
June 2005
Re: Cordia Turbo Cheap Wed, 29 June 2005 05:03 Go to previous messageGo to next message
i would just like to know if that '86 supra of yours is for sale...
Wildsupra
Re: Cordia Turbo Cheap Wed, 29 June 2005 12:13 Go to previous messageGo to next message
cheers for the advice bunky t18, have you worked on cordia's before? or is that general advice for all cars? i have NEVER worked on cordias before and im stumped. Have you had experiance with cordia's?
The car will idle fine but will not rev past 1200 AT ALL, not on half throttle full throttle nothing. I havent seen the tacho ever go past 1200
Cheers for any help though, much appreciated
Dragoncypher sorry buddy the mk3 supra is most definantly NOT for sale. I think i will be buried in that beast.
Matty
bunkyT18
Pilbara
Re: Cordia Turbo Cheap Thu, 30 June 2005 00:52 Go to previous messageGo to next message
Hey Wildsupra,
I have had too much experience with the ol cordias lol. I have had the same problems with a few of them in the past. I break the rev problem down into the following areas;
Incorrect connection of vacum lines and 'oneway' valves (technically they are actually restriction valves) I have the correct vacum lines setup diagram if you need it. It's also on the cordiapower site.
Incorrect Throttle Position Sensor setting. Not hard to fix.
Faulty knock control sensor, again not hard to fix. It's the most common problem with cordias, it's like you give it some revs and the sensor freaks cos it's sick and thinks 'oh no massif detonation!'
Rooted vacum advance on the distributor. Again no big deal.
Give me a pm if you want any more info as I have a fair bit of good info translated from the Jap factory manuals.
Another good resource is http://www.cordiapower.com/
The cordia is a great car but would be greater if only:
It was rear wheel drive.
It was a toyota.
Have a search through the cordiapower forums.
Adam
tyreburner
Re: Cordia Turbo Cheap Thu, 30 June 2005 15:38 Go to previous message
Hey,
I've had three Cordias, yes you should check Cordiapower.com. There is heaps of info there.
It sounds to me like it might be a timing problem (too far retarded) or the TPS. It is more likely to be the timing because when the TPS is out on a Cordia it usually just revs up high and stays there.
Alex
Previous Topic:FOR SALE!!1993 Toyota Chaser Immac Cond 2.4LTurbo
Next Topic:KE25 racer
Current Time: Mon Oct 26 08:42:26 UTC 2026
Total time taken to generate the page: 0.0052750110626221 seconds
