Toymods » Tech & Conversions » How to tell the difference's in Cams
FLY PSI
icon4.gif  How to tell the difference's in Cams Fri, 06 December 2002 12:09 Go to next message
I was woundering how to tell 2TG cams apart? I just got a TA22 and it came with a heap of spares, including 2 sets of 2TG cams. the numbers on the cams are the same execpt for the last no. they are: xxxxxxxx220 and xxxxxxxx222. i was wanting to know a bit about them like what duration and lift they both are? aparently one set is the standard set and the other are a mild set. any help would be great!!!! Smile Smile
5KinKP60
Finland
Re: How to tell the difference's in Cams Sat, 07 December 2002 00:39 Go to previous messageGo to next message
You need a somekinda jig fixture where rotate them camshafts. (Having them installed in an engine block works - naturally). Then you need a degree wheel and a dial gauge. Equipped with these you can find out every aspect there is to know about camshafts.
Except maybe country of origin Smile
I recently ran into two american 6-cyl cams. I friend needed to know what they were. While he made up a jig for rotating them on a table, I used my time to make up a rough degree wheel out of suitable stuff I found in a garage.
I always make proper TDC marking on engine block/crank sprocket. Ignition and cam timing marks are filed onto crank pulley. This way I myself have no need for a degree wheel at all.
This way it's a real low-labour effort to change cam timing, when for example making comparison runs on a chassis dyno. No way to accomplish that with a degree wheel system.
-A.
FLY PSI
icon4.gif  Re: How to tell the difference's in Cams Sat, 07 December 2002 14:42 Go to previous messageGo to next message
Is there a way of finding out the info i want from the codes on the cams?
5KinKP60
Finland
Re: How to tell the difference's in Cams Sat, 07 December 2002 17:18 Go to previous messageGo to next message
Who is to say whether they've been re-ground after code stamping.
Also - with a dial gauge we can double check the cam for possible grinding mistakes done by lobe grinder.
To what I've been told, it's not totally unheard of having differences in duartion/lobe separation between cams in a same camshaft. Camshafts are mass products, mistakes do happen.
I went through my re-ground Toyota cam. Class product. Everything was within specifications. Now I sleep better.
-A.
inferno
Re: How to tell the difference's in Cams Sun, 08 December 2002 00:34 Go to previous messageGo to next message
supposing the guy who owned the engine before you did the cheap thing and just swapped the #222 cam for a #220 cam (which have a lower lift, longer duration), then they should be-
#220-
Cam Shaft:
Lobe Height In 45.87 ~ 45.97
Lobe Height Ex 45.87 ~ 45.97
Cam Lift:
In 9.82
Ex 9.82
#222-
Cam Shaft:
Lobe Height In 46.37 ~ 46.47
Lobe Height Ex 46.37 ~ 46.47
Cam Lift:
In 10.27
Ex 10.27
FLY PSI
icon4.gif  Re: How to tell the difference's in Cams Sun, 08 December 2002 03:06 Go to previous message
the cams that i mentioned are spares, he told me that the ones in the car are a mild set, i will be taking the cam cover off to check the numbers on them.he also told me that he had the buckets & shims redone to suit.
Previous Topic:Sway Bars? ae86
Next Topic:fitting new springs
Current Time: Thu Nov 19 19:08:21 UTC 2026
Total time taken to generate the page: 0.01990008354187 seconds
