Toymods » Tech & Conversions » 1jz tacho problem
Chris Davey
sunny coast, qld
1jz tacho problem Tue, 28 June 2005 13:36 Go to next message
Hi guys,
I have just been trying to wire up my tacho. If you don't know it is a 1jz-gte engine running off a wolf 3d ecu and I have the jzx90 chaser dash in my car.
Since the car has been running the tacho would jump a little when I cranked the engine over and as soon as it started running it would go back to 0 and not move. I am not sure why but I assume it is dodgy wiring from dodgy mechanic.
So I thought I could fix this by running the tacho output from the wolf directly to the tacho.
The tacho output was on a plug which also has ignition ground, ignition 1,2,3 &4. I cut the wire off for the tacho output and wired it directly to the tacho wire that I found from the jzx90 wiring diagram. I connected the ignition ground to ground.
Cranked it over and exactly the same thing happened? Didn't change a thing. Any idea on how to fix this?
sideshow
Re: 1jz tacho problem Tue, 28 June 2005 21:26 Go to previous messageGo to next message
if u r runnin the tacho from an output on the ems then u will prob need a tacho booster
i have fitted these before to microtechs and ems ecus
if it was runnin ok before hand of the 1j ignitor then maybe the ems has a slightly different signal to it
Chris Davey
sunny coast, qld
Re: 1jz tacho problem Tue, 28 June 2005 22:35 Go to previous messageGo to next message
It didn't work before off the igniter.
If it jumps to 500rpm and then goes straight back to 0, is that a usual case for a tacho booster?
It just seems strange to me that it can be getting its signal from a totally different source and it does exactly the same thing.
Chris
Ribfeast
Newcastle, Australia
March 2005
Re: 1jz tacho problem Wed, 29 June 2005 04:29 Go to previous message
Give the guys at Sixworks a call, they make tacho boosters, and might tell you if you need one from your descriptions of the problem.
Previous Topic:st165 downpipe, does the 6 bolt flanges, fit the 4bolt?
Next Topic:AE86 fuel sender unit specs
Current Time: Thu Oct 22 05:03:19 UTC 2026
Total time taken to generate the page: 0.0056061744689941 seconds
