Toymods » Tech & Conversions » 4agze - gauge readings (oil, exhaust temp, fuel pressure etc)
no_tofu_speed
Jab what?!!?!
4agze - gauge readings (oil, exhaust temp, fuel pressure etc) Wed, 29 June 2005 01:00 Go to next message
This may seem stupid to those who know but I don't!!!
The gauges to monitor the engine performance such as
Oil Temp
Water Temp
Oil Pressure
Fuel Pressure
Exhaust Temp
What should each of these sit at (and range between) for a 4agze running efficiently, and also at what readings are getting to the extremes when you should "start" to worry (obviously there is a point that is going to be stupidly obvious that you should worry).
Id rather be safe than sorry.
Re: 4agze - gauge readings (oil, exhaust temp, fuel pressure etc) Wed, 29 June 2005 01:15 Go to previous message
Water temp should be between 80 - 90c. Anything over 100 I would be getting worried.
Oil pressure, at cruise I think 50psi or so is good. 4age's tend to run pretty high oil pressure though. Idle around 30psi maybe.
Fuel pressure, I believe should be around 40psi.
Unsure about exhaust temp and oil temp.
Previous Topic:oil leaking
Next Topic:2jzge Rear Seal
Current Time: Mon Oct 19 22:02:49 UTC 2026
Total time taken to generate the page: 0.01786208152771 seconds
