Toymods » Tech & Conversions » z2 88 soarer coilovers? turbo?
Brokenone
B.C. Canada
June 2005
z2 88 soarer coilovers? turbo? Wed, 29 June 2005 01:55 Go to next message
I am from Canada and I am in the proses of importing a z2 88 soarer for my brother and i was wondering does the coilover from a ma70 supra work in the z2 in not one of the air ride ones it got the 1g witch brings me to my next question. I have an r32 skyline gtst to up the boost I just put in a bleed valve. now for the 1g it twin turbo what the best way to go about this... should i shorten the wast-gate arms or do I run both the turbos throw one bleed valve...
just wondering whats some good thing to do to the car there are all most none of them out here i have only ever seen one in my life and it just drove by me so i don`t really know that much about them besides what i have read on the net
Thanks hope to here from you guys soon
mz soarer
April 2005
Re: z2 88 soarer coilovers? turbo? Wed, 29 June 2005 06:35 Go to previous messageGo to next message
just hook both turbos to the boost controler using a (T)peace works fine on mine
Brokenone
B.C. Canada
June 2005
Re: z2 88 soarer coilovers? turbo? Wed, 29 June 2005 07:12 Go to previous messageGo to next message
ok cool what kind of boost do you run i read some where i think on this forum some guy ran them at 18 for Long term and then up them to 25 and they blew up what would you think is safe? and is stock about 9 in the 88 and 11 in the 89 i have been reading alot but nothing seems set in stone alot of talk no real ancers from what i have seen
[Updated on: Wed, 29 June 2005 07:12]
ndgcpr
Pine Rivers QLD
April 2005
Re: z2 88 soarer coilovers? turbo? Wed, 29 June 2005 07:34 Go to previous messageGo to next message
i have been told the stock turbos cannot produce more then 15 psi because they are so small. i dunno if it is true but it is what i have heard
Merudo
Central Coast, NSW
February 2005
Re: z2 88 soarer coilovers? turbo? Wed, 29 June 2005 23:47 Go to previous messageGo to next message
ndgcpr wrote on Wed, 29 June 2005 17:34
this is true to a degree, as far as I know. You can try and turn the boost up more than 1 bar but the turbos are so far out of their efficiency range that you'll not make any more gains. Could be wrong though
mz soarer
April 2005
Re: z2 88 soarer coilovers? turbo? Wed, 29 June 2005 23:55 Go to previous messageGo to next message
hi im runing 14 pounds of boost for about a year and a half with no problems and yes u can run much more than 15 pounds i got to 17 pounds one night before i hit fuel cut normaly it will hit around 14 or 15 pounds im geting a turbo smart manual fuel cut defender put in on my next service and will probly run 16 or 17 pounds every day Wink
ndgcpr
Pine Rivers QLD
April 2005
Re: z2 88 soarer coilovers? turbo? Thu, 30 June 2005 02:13 Go to previous messageGo to next message
how are you varying so much? just poor management??? i was thinking if they do peak low i should just weld the wastegate shut lol
(i am kidding)
MR 1JZ
Re: z2 88 soarer coilovers? turbo? Thu, 30 June 2005 03:22 Go to previous messageGo to next message
A70 coilvers bolt straight in Smile
and dont use a bleed valve they are poo and spike a lot, go a decent EBC Smile
mz soarer
April 2005
Re: z2 88 soarer coilovers? turbo? Thu, 30 June 2005 04:04 Go to previous messageGo to next message
geting the fuel cut put in next week and tuned to run 17.18 pounds Wink so ill tell u how the car gos Wink
Brokenone
B.C. Canada
June 2005
Re: z2 88 soarer coilovers? turbo? Thu, 30 June 2005 19:11 Go to previous messageGo to next message
so that 17psi from is stock turbos you gust need to remove a fual cut??? thanks for all the info guys. so anyone know if ma70 coilovers work or not?
anyone ever swap turbos like to a ct12a/b or somthign ealch sorry guys i got alot of qusthions i am new to the hole toyota thing
[Updated on: Thu, 30 June 2005 19:25]
MR 1JZ
Re: z2 88 soarer coilovers? turbo? Thu, 30 June 2005 21:42 Go to previous messageGo to next message
MR 1JZ wrote on Thu, 30 June 2005 12:52
Brokenone
B.C. Canada
June 2005
Re: z2 88 soarer coilovers? turbo? Fri, 01 July 2005 05:19 Go to previous messageGo to next message
oops sorry i missed that that thanks Very Happy what about brakes and that stuf is most stuf on the sorur a70 compatible
MR 1JZ
Re: z2 88 soarer coilovers? turbo? Fri, 01 July 2005 05:26 Go to previous messageGo to next message
yes i have a set of front 300mm JZA70 rotors and calipers waiting to go on Smile
bolt on Smile
yay Very Happy
votoms888
Vancouver, B.C. Canada
July 2005
Re: z2 88 soarer coilovers? turbo? Fri, 01 July 2005 11:01 Go to previous messageGo to next message
Will MA70 coilovers work in an MZ20 with the air-ride? I am getting an MZ20 so it would be nice to know.
MR 1JZ
Re: z2 88 soarer coilovers? turbo? Fri, 01 July 2005 17:22 Go to previous message
they should, the air ride stuff comes right out and can be replaced with coilovers Smile
pretty sure of this...
can someone back me up?
Previous Topic:part number
Next Topic:stuck pulley
Current Time: Sun Oct 18 01:17:08 UTC 2026
Total time taken to generate the page: 0.0070250034332275 seconds
