Toymods » Tech & Conversions » 1GGTE or what?
Stryder
1GGTE or what? Fri, 06 December 2002 16:56 Go to next message
Ok I have previously posted asking what engines I could put in an SA63 and it was suggested to get a 3SGTE . . now thats just not an option $$$ wise so I was wondering what else would be available? Is a 1GGTE a viable option? If so what would be the costs and requirements?
Any replies are greatly appreciated, I really need to start beating hyundai's! Its embarrassing!
cam_RA40
Launceston, Tasmania
haha, funny little head!
Re: 1GGTE or what? Fri, 06 December 2002 21:50 Go to previous messageGo to next message
From what i understand the 1g is the best value for money conversion for the RA60 and RA65. The Sa63 obvously has a 2S engine but i'm pretty sure that the engine bay has plenty of room for a 1g. I'm not sure of the curent prices for a 1g but if money is a factor you could look at getting a non turbo 3sge it shouldn't be a too harder conversion and it will be a decent increase of power with plenty of potential.
TurboCelica
Re: 1GGTE or what? Sun, 08 December 2002 22:14 Go to previous messageGo to next message
i had the car and the engine with the bits to make it work but sold it last week Smile
the 1ggte will fir, you will need to make mounts tho, also need a sump of the NA or supercharged version? the front sump (the turbo has mid) to clear the x-member
also a bellhousing (1g slave + flywheel if a auto 1ggte)
then it will bolt upto your gearbox
not the most basic swaps but very doable.
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
icon4.gif  Re: 1GGTE or what? Mon, 09 December 2002 01:13 Go to previous messageGo to next message
You don't need a front sump (they're kinda rare).
You should be able to bash the mid-rear sump in a bit... Well that's on an R-series crossmember, not sure about the S-series one.
The front sump is much better though. But only appears in 1G-GEs, 1G-GZEs, and 1st Gen 1G-GTEs.
TRACTION_ISSUES
Re: 1GGTE or what? Mon, 09 December 2002 02:21 Go to previous messageGo to next message
Pfffttt....front sump bullshit......
I used to flog the arse out of my 1G, and never had any problems with the mid sump. Has it been proven that the front sump is better?? Sure, it may be bigger than the mid one, but do you think toyota would have built the mid sump on the last generation 1GGTE's, if it was inferior to the front design?? You must also remember that the mid rear sump IS on the highest HP output 1G aswell, which is also the one that would require the most oil flow and pressure....
But who cares, im just in it for a rant (and a break from working on the celica!)
Dabbid
Yowie Bay, Sydney
Re: 1GGTE or what? Wed, 11 December 2002 10:41 Go to previous messageGo to next message
y not use a 4a sump? and few pieces of the 1g sump
worked for me Smile
until ofcourse the dickhead panel beater thought it was a cross member, guess u all know what happened there!!!!
Re: 1GGTE or what? Thu, 12 December 2002 00:55 Go to previous message
The front sump also comes on a 1GEU!
Previous Topic:Cressida GX60 wont start
Next Topic:18RGU throttle setup
Current Time: Sat Sep 12 14:08:50 UTC 2026
Total time taken to generate the page: 0.0052781105041504 seconds
