Classifieds » Parts Wanted » parts for 4A-GE needed
CelicaMan
Pocatello, Idaho, USA
icon4.gif  parts for 4A-GE needed Fri, 06 December 2002 22:18 Go to next message
I'm looking for parts for a 4A-GE to put into my '71 celica. Here is a list:
oilpan (center sump) with pick-up tube
intake manifold (carborated preferably)
exhaust manifold or headers
distributor with machanical and vaccume advance
motor mounts off of a sprinter RWD
throwout bearing
I also need advise for an easier install and I'm low on money. Any help would be great.
CelicaMan
Re: parts for 4A-GE needed Tue, 10 December 2002 21:30 Go to previous messageGo to next message
I had a throwout bearing built by a local machinist and all i really need is a distributor with the mechanical and vaccume advances. Can anyone please help me with where I can locate this part or if I can even get one. thanx
Grega
melbourne.victoria.austra...
Re: parts for 4A-GE needed Wed, 11 December 2002 00:47 Go to previous messageGo to next message
hey dude, couple of things :
1. center sump (you sure, what model celica, i'm putting a 4AGE in a ta22 and it needs a front mounted sump - so either RWD or FWD fits fine.
2. intake manifold - 4AGE's only came as EFI as far as i'm aware - so this would be a custom application. there is a mob here in australia that do them : http://www.redlineauto.com.au/manifold.html
3. custom headers would need to be made, no off the shelf headers for this motor for a 71 celica. a rwd cast manifold would be a good start tho (hard and expensive to get now)
4. distributor with mech advance - custom item again.
5. the engine mounts - custom items again. ae86 sprinter items will not bolt up to the early celica crossmember.
6. a throwout bearing for a T50 from an ae86 will be what you need. if you have a T50 gearbox in the celica now it won't bolt up to the 4AGE - different bellhousing and different box (20 spline in celica vs 22 spline in ae86)
you also need to think about water fittings and radiator too..
CelicaMan
icon14.gif  Re: parts for 4A-GE needed Wed, 11 December 2002 22:01 Go to previous messageGo to next message
Hey Grega,
Thanks for the help buddy. About the oil-pan, yeah I need a center sump pan because the cross-member in the American models is different from the Australian models. The cross-member curves to the front of the car instead of the back. All my research has led me to believe this because everyone at toymods tells me that I need the front sump pan. I have changed motors twice already and currently have a 20R in it, which has a center sump pan. I did plan on building an intake manifold that will fit four (4) Mikuni carbs. And I have an exhaust header for a '85 Corolla GTS on the way that I hope will fit. I'm not sure if I have a T-50 trany but I do know it came out of a '86 Corolla GTS. But I got the throwout bearing from an 18R-C modified to work. I do have a plan for the cooling setup and have most the parts I need. As far as I know, there was never a model of the Sprinter made for America, but I think the Corolla GTS (RWD) is the closest thing to it, because most my parts came from this kind of car. About the distributor, will the one off the fuel injected 4A-GZE work. That's what I have and also what the head came off of. I can build everything else but the distributor so that is the most important thing. Thanks again for the help and please get back to me as soon as possible because I plan on starting my project over christmas break. Thanks
Oh, yeah. My Celica is a 1971 RA20. I have not seen this model on toymods yet but I think it's just the difference in the Australian models and the American models.
CelicaMan
Re: parts for 4A-GE needed Tue, 17 December 2002 20:30 Go to previous messageGo to next message
i'm still looking for a center-sump oilpan for a 4A-GE or 4A-FE, pretty much any motor that starts with 4A. any help would be great.
._T_.
Re: parts for 4A-GE needed Tue, 17 December 2002 23:27 Go to previous messageGo to next message
celicaman, there is no such thing as a center sump 4age - thay are all front. you will have to custom make it to suit your application
T
Grega
Re: parts for 4A-GE needed Wed, 18 December 2002 02:15 Go to previous messageGo to next message
toby is right there is no center sump model of 4AGE! you'll have to fab/cut&shut a FWD/RWD one to suit - will also need to move the oil pickup back a bit too.
re: the 4AGZE dizzy no it won't work - you'll need a computer to drive it or get an ignition place to rig you up an old style dizzy to suit.....last time i checked one was $500AUD which is a bit of money...
CelicaMan
Re: parts for 4A-GE needed Wed, 18 December 2002 22:20 Go to previous messageGo to next message
you guys kick ass. thats just what i needed to know.
thanks fellas
Grega
Re: parts for 4A-GE needed Wed, 18 December 2002 23:02 Go to previous messageGo to next message
no worries dude Very Happy
._T_.
Re: parts for 4A-GE needed Thu, 19 December 2002 01:45 Go to previous messageGo to next message
you can set up a 4ac dizzy with electronic k series dizzy internal (or possible 4afc) to run a 4age on carbs - i have the instructions somewhere.
T
CelicaMan
Re: parts for 4A-GE needed Thu, 19 December 2002 22:30 Go to previous messageGo to next message
"you can set up a 4ac dizzy with electronic k series dizzy internal (or possible 4afc) to run a 4age on carbs - i have the instructions somewhere."
hey T
if you could find those instructions i would really appreciate it. i'm in desperate need of a working dizzy.
thanks man
Grega
Re: parts for 4A-GE needed Fri, 20 December 2002 01:31 Go to previous messageGo to next message
i wouldn't mind a look at those instructions either T.
celicaman i have a K series dizzy which needs an external ignitor of some type - which is sitting in a box if you want it let me know.
._T_.
Re: parts for 4A-GE needed Fri, 20 December 2002 03:24 Go to previous messageGo to next message
ok here's the instructions:
You actually need two distributors, one from the 3A/4A, and one from the 3T or 4K-E.
The 3A/4A distributor is the one you'll end up using, but you have to gut it first, then install the "guts" from the 3T or 4K-E distributor. When you're done, you shoulld have a magnetic trigger mechanical advance distributor that will fit a 4A-G.
4k motor generally found in rwd starlets (one can be found at bill's place!!, otherwise no luck finding them in aus)
4afc (carb ae92 4af poverty-pack motor) should also have an electronic dizzy - you should be able to do the above mod on it too.
T
CelicaMan
Re: parts for 4A-GE needed Sun, 22 December 2002 20:39 Go to previous message
grega,
hey man if i can't find the right dizzy anywhere near by then i will let you know if i need the one you have. i really need this part so i'll keep in touch
Previous Topic:1g mounts
Next Topic:GFB MACH1 bov ASAP
Current Time: Sun Oct 18 01:15:24 UTC 2026
Total time taken to generate the page: 0.0058510303497314 seconds
