Toymods » Tech & Conversions » M series engine comparison (Flywheels, Sumps, Engine mounts)
wilbo666
M series engine comparison (Flywheels, Sumps, Engine mounts) Wed, 29 June 2005 12:21 Go to next message
I've taken some pictures that may be of use, it's information that I feel may be helpful to some persons at some stage.
I'll list this so people might be able to use the shite search function to find this thread again one day 5M, 5ME, 5M-E 5m, 5me, 5me, 7m, 7mge, 7m-ge, 7M, 7MGE, 7M-GE.
First off, a comparison of a MA61 fylwheel and clutch (225mm) vs a MA70 flywheel and clutch (240mm).
You can see that the outer diameter of the 7M flywheel is quite a bit larger (obscures the ring gear). The rest is self explanatory. Of note is the oily looking substance on the 7M flywheel, this was just to avoid it rusting any further during storage.
http://everest.fit.qut.edu.au/~n4150414/Car/Online%20M%20series%20Information/225mm%20vs%20240mm%20Flywheel/tn_DSC01257.JPG
http://everest.fit.qut.edu.au/~n4150414/Car/Online%20M%20series%20Information/225mm%20vs%20240mm%20Flywheel/tn_DSC01259.JPG
http://everest.fit.qut.edu.au/~n4150414/Car/Online%20M%20series%20Information/225mm%20vs%20240mm%20Flywheel/tn_DSC01274.JPG
Secondly we have a comparison of a front sump (MX83) vs a mid rear sump (MA70). Of note, if you wish to change from a mid rear sump to a front sump or vice versa, you will be require to drill a 10.5mm hole into the engine block for the oil dipstick, and of course plug the existing dipstick hole by some means. There is a casting mark where the new hole should be drilled regardless of original sump configuration. Images explain the other differences (also note the dong in the second picture, that is me Razz).
http://everest.fit.qut.edu.au/~n4150414/Car/Online%20M%20series%20Information/Front%20vs%20Mid-Rear%20Sump/tn_DSCF2489.jpg
http://everest.fit.qut.edu.au/~n4150414/Car/Online%20M%20series%20Information/Front%20vs%20Mid-Rear%20Sump/tn_DSCF2490.jpg
http://everest.fit.qut.edu.au/~n4150414/Car/Online%20M%20series%20Information/Front%20vs%20Mid-Rear%20Sump/tn_DSCF2491.jpg
http://everest.fit.qut.edu.au/~n4150414/Car/Online%20M%20series%20Information/Front%20vs%20Mid-Rear%20Sump/tn_DSCF2496.jpg
Finally we have a comparison of MZ10 engine mounts vs MA70 (early model before the crossmember change) engine mounts, I suspect any front sump (bar late model MX83's) M series engine mounts are the same e.g. MX62, MX73, MX83 (early models before the crossmember change), MA61, MZ10, MZ11, MZ12 etc. As the picture show they bolt up perfectly, even around the oil cooler drain and return lines. The MA70 mounts are from an early MA70 as well (86).
http://everest.fit.qut.edu.au/~n4150414/Car/Online%20M%20series%20Information/MZ10%20vs%20MA70%20%20Engine%20mounts/tn_DSCF2465.jpg
http://everest.fit.qut.edu.au/~n4150414/Car/Online%20M%20series%20Information/MZ10%20vs%20MA70%20%20Engine%20mounts/tn_DSCF2474.jpg
http://everest.fit.qut.edu.au/~n4150414/Car/Online%20M%20series%20Information/MZ10%20vs%20MA70%20%20Engine%20mounts/tn_DSCF2479.jpg
I hope this information is useful to people as a reference source one day in the future. If someone (Ed?) wants to move this into the tech & conversion sticky, by all means feel free.
[Updated on: Wed, 29 June 2005 12:24]
Re: M series engine comparison (Flywheels, Sumps, Engine mounts) Wed, 27 July 2005 02:43 Go to previous messageGo to next message
Thought I'd add something to this.
I took some photos of a 5MGE vs 7MGTE vs 1UZFE alternators the other day.
5MGE alt is supposedly 65A
7MGTE alt is supposedly 80A (autobox)
1UZFE alt is supposedly 100A
Here are some pics.
http://conceptual.net.au/~peewee/alternator/top_aligned_side_profile_1.jpg
http://conceptual.net.au/~peewee/alternator/top_aligned_side_profile_2.jpg
http://conceptual.net.au/~peewee/alternator/top_aligned_top_profile.jpg
http://conceptual.net.au/~peewee/alternator/mount_aligned_side_profile.jpg
http://conceptual.net.au/~peewee/alternator/mount_aligned_top_profile.jpg
5M vs 7M
http://conceptual.net.au/~peewee/alternator/5M_vs_7MGTE_mount_compare_1.jpg
5M vs 7M
http://conceptual.net.au/~peewee/alternator/5M_vs_7MGTE_mount_compare_2.jpg
7M vs 1UZ
http://conceptual.net.au/~peewee/alternator/7MGTE_vs_1UZFE_mount_compare_1.jpg
7M vs 1UZ
http://conceptual.net.au/~peewee/alternator/7MGTE_vs_1UZFE_mount_compare_2.jpg
bbaacchhyy
Re: M series engine comparison (Flywheels, Sumps, Engine mounts) Wed, 27 July 2005 02:50 Go to previous messageGo to next message
The Alternator fitted to my Soarer 7M-GTE is reortedly 100A (from feedback from the part no. via the EPC and Mitch).
So looking at the pics, the 1UZ alt will fit a 7M-GTE ? It is just in the last opicture that the boss is deeper at the back ?
Is the belt pulley the same diameter ?
Michael B
Re: M series engine comparison (Flywheels, Sumps, Engine mounts) Wed, 27 July 2005 02:54 Go to previous messageGo to next message
I think 7M alt pulley is 5 ribs where 1UZ is 6 ribs.
And yeah, its just the boss deeper.
But the connections are on a different angle.
bbaacchhyy
Re: M series engine comparison (Flywheels, Sumps, Engine mounts) Wed, 27 July 2005 02:58 Go to previous message
CrUZsida wrote on Wed, 27 July 2005 12:24
I'm pretty sure that mine is a 6PK belt - I'll check
Michael B
Previous Topic:ta22 front brake upgrade
Next Topic:3t-gteu vaccum diagram help?
Current Time: Mon Oct 19 17:52:02 UTC 2026
Total time taken to generate the page: 0.0047199726104736 seconds
