Toymods » Tech & Conversions » Turbo swap on 1jz
Bounty
_Sydney _
Turbo swap on 1jz Sat, 07 December 2002 04:06 Go to next message
Just saw this post on another forum some guy has CT20A turbos brand new wants like a grand for them, would they bolt up on a 1jz?
http://board.performanceforums.com/forums/attachment.php?s=&postid=394540
666supra
U.S.A
Re: Turbo swap on 1jz Sat, 07 December 2002 04:37 Go to previous messageGo to next message
No
Bounty
_Sydney _
Re: Turbo swap on 1jz Sat, 07 December 2002 07:18 Go to previous messageGo to next message
Ok no worries. Smile
Re: Turbo swap on 1jz Sun, 08 December 2002 08:44 Go to previous messageGo to next message
as has been mentioned elsewhere... the stock turbos are good for about 450 hories... unless you want more than that, dont swap your turbos, 'cause tehre is a LOT of money to be used once you go down that road
SUPRAGTE
North Sydney
Re: Turbo swap on 1jz Sun, 08 December 2002 09:01 Go to previous messageGo to next message
Nah man, stock ones arn't rated that high. Someone else may be able to tell us what they can actually put out.
If the stock ones put out that much I'd put a 1J in mine years ago...
mm... I wasn't really sure on the figure, but that one sounded familiar. maybe it was 350? I dont know Smile
Bugman
Re: Turbo swap on 1jz Sun, 08 December 2002 09:04 Go to previous messageGo to next message
225rwkws wasnt it?
Goku
Re: Turbo swap on 1jz Sun, 08 December 2002 10:02 Go to previous messageGo to next message
hey my soarer makes 225rwkws on blown turbos
on dyno day 3 it made 199.3 rwkws on 11 or 12 psi
then a retune gave it 225 rwkws..
i am puttin on steel wheeled ct12a's now so should get more
b4 you eva replac e turbos get an aftermarket ems
Re: Turbo swap on 1jz Sun, 08 December 2002 11:57 Go to previous messageGo to next message
US-spec turbos are good for about 450hp apparently, but they're quite a bit bigger than the Jap turbos.
Soarer
Wollongong
Re: Turbo swap on 1jz Sun, 08 December 2002 11:58 Go to previous messageGo to next message
Have EMS (the actual brand) brought out a computer that works properly with the 1JZ yet ? From what I'd heard, there is an issue with some stepper motor, or something to do with the ignitors (not sure which).
Re: Turbo swap on 1jz Sun, 08 December 2002 12:21 Go to previous messageGo to next message
I'd like to know about 1jz ems systems as well, since that's one of the brands I'm looking at getting to replace me ecu
Goku
Re: Turbo swap on 1jz Mon, 09 December 2002 03:09 Go to previous messageGo to next message
hey. my ems woreks fine..
the problems associated with idle control and that were just tuning problems associated with a bad tuning shop (Identity removed - There are 3 sides to every story, One from each side and then theres the truth. In the interest of fair play this has been removed) otherwise its fine now and runs well.. i got 50rwkws from tuning which seems unbelievable but true.
also us spec turbos? wtf? your on crack
[Updated on: Mon, 09 December 2002 04:26] by Moderator
Re: Turbo swap on 1jz Mon, 09 December 2002 04:40 Go to previous messageGo to next message
I meant US-spec 2JZ turbos are good for 450hp. These are slightly bigger than Jap-spec 2JZ turbos. I'm pretty sure I'm not on crack.
Goku
Re: Turbo swap on 1jz Mon, 09 December 2002 08:40 Go to previous messageGo to next message
sorry i wont name names anymore
anyway i recall the crack comment i didnt know what you were tralkin about..
humble
Brisbane, QLD
Re: Turbo swap on 1jz Mon, 09 December 2002 21:13 Go to previous messageGo to next message
Yeah, I can confirm what norbie said. I heard the same thing. US-spec 2JZ turbos (larger ball bearing type) are capable of upto 450HP.
Remedy
Southern Sydney
Re: Turbo swap on 1jz Mon, 09 December 2002 21:26 Go to previous messageGo to next message
Wouldn't they be in somekind of sequential setup though....
Do they bolt straight up to the 1JZ manifold?
Re: Turbo swap on 1jz Mon, 09 December 2002 23:19 Go to previous messageGo to next message
Yes they are sequential and no they don't bolt up to a 1JZ manifold (not without mods anyway).
jza70-mel
Perth WA
Re: Turbo swap on 1jz Tue, 10 December 2002 09:46 Go to previous messageGo to next message
I didn't think any Toyota turbos were ball bearing
0zwilly
Re: Turbo swap on 1jz Tue, 10 December 2002 10:49 Go to previous messageGo to next message
Then can bolt the 2jz mainfold stright into 1jz or not?
then just source the whole assembly and bolt into it...if it does work...
mx83toy
Re: Turbo swap on 1jz Tue, 10 December 2002 13:48 Go to previous messageGo to next message
nope ive heard that its not good bang for buck!!! they came on late and when they got going they were not a big power gain...the cash is better spent high flowing the ct12a's or put into savings for the gt3040 *drool*
remedy how you doing man!!! pm me
Re: Turbo swap on 1jz Tue, 10 December 2002 23:42 Go to previous message
No, the 2JZ manifold won't fit on a 1JZ head.
Previous Topic:Twin Pipe design...
Next Topic:t25 4age
Current Time: Fri Nov 20 05:40:20 UTC 2026
Total time taken to generate the page: 0.049755096435547 seconds
