Toymods » Tech & Conversions » y wont my engine idle
ezzie
June 2005
icon4.gif  y wont my engine idle Thu, 30 June 2005 07:27 Go to next message
jus wondering if anyone can help? i have a 20 valve in my rolla and i cant get it to idle properly.i recently installed a higher psi fuel pump & fuel is getting to the motor,i have cleaned the injectors so i know they are squirting,im running single coil packs through an mtx8 microtech & 8.8mm leads & had the altenator rebuilt so i know its sparking,quad throttle bodies with uni filters are also bolted up so i got no dramas with my intake.what is up with this thing?anybody?
Re: y wont my engine idle Thu, 30 June 2005 07:32 Go to previous messageGo to next message
air leak or quads not balanced, or crap MAP signal to microleb. do you have a MAP pulsation dampener in there somewhere?
10sec_rx7
Syndey
Re: y wont my engine idle Fri, 01 July 2005 05:15 Go to previous messageGo to next message
the mictotech *should* be running in TPS mode so you could have the vacuum line off and it wouldnt matter,
did it idle correctly before the fuel pump was put in?
Dale
Re: y wont my engine idle Fri, 01 July 2005 07:22 Go to previous message
heh heh, the MT SHOULD be able to run it even with low vacuum from quads.. Wink Razz 75kpa absolute is plenty (25kpa vacuum)
Previous Topic:flooded hilux, wont start help
Next Topic:Norbie has a big, huge DONG of a box ;)
Current Time: Fri Nov 20 08:16:42 UTC 2026
Total time taken to generate the page: 0.013298988342285 seconds
