Toymods » Tech & Conversions » 3sge valve stem seals and piston ring questions
dingaling
tas
3sge valve stem seals and piston ring questions Thu, 30 June 2005 10:51 Go to next message
Toyota want about $150 for a new set of valve stem seals. I asked if 7m ones will fit as i have a spare 24 of the buggers. Toyota say that the intake are the same, the exuast ones are different. (might be the other way around, can't remember)
So does anyone know if the valve stem seals are indeed different for the intake and exuast vavles? And if 7m valve stem seals will fit?
Also this particular gen1 3sge is burning an unhealthy amount of oil but drives perfectly (ie no loss of power)
I did do a quick and i mean real quick compression test on the number 1 cylinder on a cold engine and it came out at aroung 120PSI which did seem abit low, would you suspect the rings bieng worn and allowing it to burn so much oil?
Will be doing a proper comp test this weekend. But would like to diagnose if it's valve stem seals or rings. Any tips would be appreciated.
dingaling
tas
Re: 3sge valve stem seals and piston ring questions Fri, 01 July 2005 01:46 Go to previous messageGo to next message
Anybody?
here's a breakdown.
Will 7m-gte valve stem seals work in a 3sge engine?
Are the intake valve stem seals different to the exuast valve steam seals? (on a gen1 3sge engine)
berad
Re: 3sge valve stem seals and piston ring questions Fri, 01 July 2005 02:06 Go to previous messageGo to next message
only one way to find out Razz
dingaling
tas
Re: 3sge valve stem seals and piston ring questions Fri, 01 July 2005 02:13 Go to previous messageGo to next message
Bugger, i want answers. nobody knows this stuff?
nobody's changed there valve stem steals on a gen1 3sge before?
anyone with an EPC could maybe check part numbers and see if they are different or the same??
dingaling
tas
Re: 3sge valve stem seals and piston ring questions Fri, 01 July 2005 10:53 Go to previous messageGo to next message
RAH!
FWDCelica
sydney,nsw.oz.
Re: 3sge valve stem seals and piston ring questions Fri, 01 July 2005 22:03 Go to previous messageGo to next message
Ask Toyota Spare Parts.
The compression issue could be the Valves/Seats.
They do wear out and need re-seating.
dingaling
tas
Re: 3sge valve stem seals and piston ring questions Sat, 02 July 2005 05:50 Go to previous message
yeah will just have to take toyota's word for it.
The valves are seating perfectly, alot of carbon was removed when i had the head off and they seat perfectly now.
I will rule the piston rings out of the equation as i did a proper compression test and got 180PSI across all 4 cylinders.
Looks like valve stem seals are the cause of burning oil.
Previous Topic:What ecu do you recommend for an AE86 JDm spec?
Next Topic:ST185 FMIC questions...
Current Time: Thu Oct 22 08:55:39 UTC 2026
Total time taken to generate the page: 0.0050947666168213 seconds
