Toymods » Tech & Conversions » Clutch for 900kg / 160hp
September_Squall
Melbourne, Australia
March 2005
Clutch for 900kg / 160hp Thu, 30 June 2005 13:46 Go to next message
Context:
I need a clutch.
Informations:
I'm building a motor for a 900kg road registered car intended for Supersprint and other tarmac events.
It's high rev naturally aspirated (no turbo torque behaviour), and I'm estimating around 160hp or 120kw at the flywheel.
It's based on a 2T, so if factory flywheel is retained the clutch face is 200mm.
Questions:
Will the standard clutch (with new OEM-style friction plate) be capable of standing up to this application?
If no, can I use the standard pressure plate with a custom friction plate to achieve an acceptable result?
If no, what pressure plate and friction plate combos should I look into?
I know there's no real exact answer, but I have no real clutch experience, so suggestions and experience is welcome.
[Updated on: Thu, 30 June 2005 13:54]
4agte
Toronto, Downtown
Re: Clutch for 900kg / 160hp Thu, 30 June 2005 13:57 Go to previous messageGo to next message
my thoughts is that an organic face clutch with a higher clamping force may be fine but you may want to go for something a little more exotic for racing like a ceramic button or brass button but i have no experience with 2t's
September_Squall
March 2005
Re: Clutch for 900kg / 160hp Sat, 02 July 2005 02:50 Go to previous messageGo to next message
Thanks for your input. Nobody ever put a clutch behind a 160hp N/A 4A-GE with 200mm clutch before? What I'm asking is pretty mich the same thing, right?
HyDrA
Adelaide, SA
Re: Clutch for 900kg / 160hp Sat, 02 July 2005 23:54 Go to previous message
I'd say go for a button clutch if you're gonna be hammering it a bit. If you want to keep a bit of street driveability then consider a cushioned button clutch.
http://xtremeclutch.com.au/
Previous Topic:truck turbo?
Next Topic:F20C Into rear wheel drive corollas {eg:ae86}
Current Time: Wed Oct 28 05:54:00 UTC 2026
Total time taken to generate the page: 0.0055460929870605 seconds
