Toymods » Tech & Conversions » 7MGTE Manual Swap into MZ20 Please Help
votoms888
Vancouver, B.C. Canada
July 2005
7MGTE Manual Swap into MZ20 Please Help Fri, 01 July 2005 10:49 Go to next message
I am buying an MZ20 Soarer. There is no one who knows much about the Soarer here so please help. I need to know how hard it is to do a manual swap.
What parts do I need exactly?
How hard is it?
Do I need a manual ECU?
Cost?
Is it worth it?
Should I just try and find a GZ20 with manual 1G in it?
Can I swap a manual 1JZ into an auto MZ20 in the future?
ndgcpr
Pine Rivers QLD
April 2005
Re: 7MGTE Manual Swap into MZ20 Please Help Fri, 01 July 2005 10:57 Go to previous messageGo to next message
1.well if it is auto you will need pedals, belhousing ect.
2.I wouldn't think it is hard if you know what your doing, a few people have.
3.No, but it would be better if you do have a man ECU. You can run a manual with an auto ECU but not the other way around.
4.depends on how much your are going to do
5.depends on how much you want a manual
6.GTE and 7M's are different motors. again depends on what you really want out of it
7.yes. you can do anything if you have the money.
I am sure someone else will come give you specific details but that is my thoughts.
BlackSupra
Re: 7MGTE Manual Swap into MZ20 Please Help Fri, 01 July 2005 10:59 Go to previous message
Get an R154 from an MA70 supra.
You will need gearbox, bellhousing, clutch, shifter, slave, gearbox crossmember, tailshaft and something to cut a hole in the tranny tunnel to fit the shifter.
Cost = alot.
Don't need a manual ecu, just got to fool the auto ecu with the neutral start switch.
Worth it... Yes.
Gz20 = slow and boring
1JZ will bolt right in if you can find a JZA70 supra half cut and crossmember. If you already have the R154 gearbox then you will need a new JZ bellhousing for it.
Previous Topic:My brakes are screwed, why?
Next Topic:MX-62 Cressida Engine Conversion
Current Time: Wed Nov 25 17:34:56 UTC 2026
Total time taken to generate the page: 0.026114940643311 seconds
