Toymods » Tech & Conversions » 1j turbo
Kronic
Darwin
July 2005
1j turbo Sat, 02 July 2005 07:11 Go to next message
just bought a 1j twin turbo powered jzz30 soarer
lookin to change the turbos.. now i know the standard size is 2 ct12, my question is how well would 2 ct26 fit? would this be possible without to much screwin around? ideally i would love to do a large single conversion but thats abit outside my price range atm. your thought and past technical experience would be greatly appreciated
manmx83
Re: 1j turbo Sat, 02 July 2005 08:16 Go to previous messageGo to next message
get a dump pipe,good exhaust and wind up the boost to 15 psi,good for 300+ rwhp in a manual.[stock turbos]
regardind twins ,there is no CHEAP easy fix.steel wheeled ct12a's or HKS t3's all run into dollars.use the Search function for plenty of info.look at the for sale mechanical section for the aforementioned turbos.Cheers.Pete.
Smile
Kronic
Darwin
July 2005
Re: 1j turbo Sat, 02 July 2005 09:07 Go to previous messageGo to next message
but can they run 15psi all day, everyday with the above mentioned mods?
ps decent front mount will be on the car
ae95
Re: 1j turbo Sat, 02 July 2005 09:20 Go to previous messageGo to next message
do a big single conversion
Kronic
Darwin
July 2005
Re: 1j turbo Sat, 02 July 2005 09:35 Go to previous messageGo to next message
love to cant afford it, jus yet. can get a new blitz t61 kit for about 6 grand though. to much atm
manmx83
Re: 1j turbo Sat, 02 July 2005 09:55 Go to previous messageGo to next message
Yep,some say they can run 17psi for long periods but 15 is a figure most agree is safe.A good exhaust and dump pipes also helps the turbos last due to less back pressure and heat.Cheers.Pete.
peeack
Re: 1j turbo Sat, 02 July 2005 12:04 Go to previous messageGo to next message
Mine have been running 15 PSI for ages, not sure on the exact time, but plenty long enough. The rear one is still holding togeather, and that's the first that will go in 1J's.
Is it possible to put the CT26 + manafold from the VVTI 1J on the non VVTI 1j?
Re: 1j turbo Sun, 03 July 2005 00:32 Go to previous messageGo to next message
That was asked not very long ago and I think the answer was no, due to different exhaust ports?
It's not really going to be worth it for a 2xCT26 conversion... going past stock turbos you're going to need new injectors, which is going to mean a new tune. once you consider the manifold and piping costs, the actual turbos themselves are only a part of the conversion cost Smile
stick with the stockies for an easy 220rwkw (or stretch it to 250 if that's all you're ever going to want), much more than that and it's single turbo time.
mx83toy
Re: 1j turbo Sun, 03 July 2005 01:18 Go to previous messageGo to next message
draven wrote on Sun, 03 July 2005 10:32
or twin gt28r's 350 - 400KW at the treads is possible.
For every action there is a reaction. Never forget that!
Stock route is nice.
Soarer
Wollongong
Re: 1j turbo Sun, 03 July 2005 01:41 Go to previous message
peeack wrote on Sat, 02 July 2005 22:04
The VVTi 1JZ uses a CT15B, not a CT26. The manifolds are not interchangeable either due to different head/port design as already mentioned.
Previous Topic:SR20 conversion
Next Topic:20v head on 4A-GZE?
Current Time: Wed Oct 28 13:08:05 UTC 2026
Total time taken to generate the page: 0.0059089660644531 seconds
