Toymods » Tech & Conversions » Crank Angle Sensor on 2TG
EMP-2TG
Carlingford, Sydney
Crank Angle Sensor on 2TG Sun, 08 December 2002 09:33 Go to next message
I want to set up my 2TG with 4 coils
which means a crank angle sensor
ive heard of ppl adapting 13B type sensors with a plate on the
front of the crank
id love to find out more info on setting up somthing like this
ive had a look round on the net but i didnt find anything of any use to me
i noticed that MSD are now selling kits that go on the front of V8's
so there must be some way of doing this
there is an artical in and old hot4's but it tells u crap all
thanks Smile
FLY PSI
icon4.gif  Re: Crank Angle Sensor on 2TG Sun, 08 December 2002 09:44 Go to previous messageGo to next message
Ive heard of using a CA18 cas, in the place of the dizzy but that was for anoughter motor. You get the Std dizzy cut and shut with a CAS and that should do the trick. Im going to get one done on my 2TG early next year.(i have a spare dizzy so my car wont be off the road when im getting it done) Smile Smile
EMP-2TG
Carlingford, Sydney
Re: Crank Angle Sensor on 2TG Sun, 08 December 2002 09:54 Go to previous messageGo to next message
really?
ok i can see how it would work
who does this convertion?
and do u know how much it would cost?
+ any1 else got some ideas on this
it will be run off a microtech MTX 8
thanks Smile
thetoyman75
Club President
Re: Crank Angle Sensor on 2TG Mon, 09 December 2002 04:17 Go to previous messageGo to next message
Guys,
Speak to YelloRolla. Jason can make you a Crank angle sensor kit that will do the trick just nicely. No Idea of cost but I have seen it at work on 3 cars already with no complaints. Worst case senario you may need to fit a 3TGTE crank pully Smile (Not sure on that)
Other alternatice is sensors on the cam and flywheel but this is more of a headache to set up and more costly. (Mine is like this)
Hope that helps.
tanman
Re: Crank Angle Sensor on 2TG Mon, 09 December 2002 07:31 Go to previous messageGo to next message
Hey Rod,
Can I have some more details on your setup. i will be removing the dizzy to make way for my new intake manifold.
Stephen
EMP-2TG
Carlingford, Sydney
Re: Crank Angle Sensor on 2TG Mon, 09 December 2002 10:06 Go to previous messageGo to next message
ok will do Smile
jason u around mate?
is there another meeting this year?
FLY PSI
icon4.gif  Re: Crank Angle Sensor on 2TG Mon, 09 December 2002 11:10 Go to previous messageGo to next message
Im going to a place after work tomorrow that i belive can do that sort of work(cut and shut a dizzy with a CAS) i will let you know how i go and how much it should cost.
I also heard that Rigoli in sydney has done this sort of mod befor.
TE72_Turbo
Re: Crank Angle Sensor on 2TG Mon, 09 December 2002 12:00 Go to previous messageGo to next message
First of all, what computer do you plan to use??
I cant remember the details of Jason's setup, but on my 3TGTE I used an alloy disc 200mm in diameter on the crank pulley, with two rare earth magnets mounted near the edge on the back of the disc, one with the north pole facing outwards, one with the south. These pass a 2 channel hall effect sensor to send the signal to the ECU for both home (TDC #1cyl) and trigger pulses.
Works brilliantly with the Haltech E6K. Very Happy
Phil
FLY PSI
icon4.gif  Re: Crank Angle Sensor on 2TG Mon, 09 December 2002 12:09 Go to previous messageGo to next message
I will most probably be useing a Microtech MT8 i have laying around which is set up to be used on a CA18det, i also have the idnition modual for it so that is why im thinking of using the CA18det CAS.
EMP-2TG
Carlingford, Sydney
Re: Crank Angle Sensor on 2TG Mon, 09 December 2002 12:27 Go to previous messageGo to next message
kool id love to know a price
thanks Smile
im also using a microtech but MTX8
YelloRolla
On your mum!
Re: Crank Angle Sensor on 2TG Sat, 14 December 2002 00:31 Go to previous messageGo to next message
Josh,
Your MTX 8 Should be able to run off a number of different trigger options. Find out from Microtech what they recommend, and then we may discuss how to do it.
One Cat - Many ways to skin it.
Ph me if you like on 0402 030 561. Alternatively drop me an email.
Regards
Jason
EMP-2TG
Carlingford, Sydney
Re: Crank Angle Sensor on 2TG Sat, 14 December 2002 01:16 Go to previous message
ok thanks jason Smile
ill contact my microtech guy
and see what he recommends
and ill get back to u if i need some help with it Smile
Previous Topic:22RE not sparking.
Next Topic:Cruise control
Current Time: Thu Nov 19 00:44:52 UTC 2026
Total time taken to generate the page: 0.024294137954712 seconds
