Toymods » Tech & Conversions » MA61 Vac line - but where does it go to ???????
bbaacchhyy
MA61 Vac line - but where does it go to ??????? Sun, 03 July 2005 03:00 Go to next message
Guys,
I am soon in the process of completing the engine (once the rad gets here), and can't for the life of me remember where this bloody hose goes Mad Mad Embarassed Embarassed
http://img205.imageshack.us/img205/816/200507030478yk.jpg
It is an 1983 MA61 with 7M-GTE. The hose I am after is the small one with the arrow
Michael B
Re: MA61 Vac line - but where does it go to ??????? Sun, 03 July 2005 04:17 Go to previous messageGo to next message
charcoal cannister and/or vaccum-operated cruise-control accuator (if fitted)
wilbo666
Re: MA61 Vac line - but where does it go to ??????? Sun, 03 July 2005 04:27 Go to previous messageGo to next message
Yep, charcoal canister purge (I think its called purge?).
Charles I thought the small line coming off the large line was for the cruise? Not that it matters its all engine manifold pressure regardless Smile
Re: MA61 Vac line - but where does it go to ??????? Sun, 03 July 2005 04:30 Go to previous messageGo to next message
yah ... purge would make sense - you dont want petrol fumes making their way into the booster Embarassed
bbaacchhyy
Re: MA61 Vac line - but where does it go to ??????? Sun, 03 July 2005 06:25 Go to previous messageGo to next message
wilbo666 wrote on Sun, 03 July 2005 13:57
Cheers Wilbo, I reckon you are right. The large one is for the Cruise
BlackSupra
Re: MA61 Vac line - but where does it go to ??????? Sun, 03 July 2005 08:00 Go to previous messageGo to next message
small one was cruise on my car, removed actuator and blanked it.
Re: MA61 Vac line - but where does it go to ??????? Sun, 03 July 2005 09:34 Go to previous messageGo to next message
I blanked mine too, but in retrospect it would have made a great line to run boost guage off
Evil_Foetus
Ballarat, Victoria
Re: MA61 Vac line - but where does it go to ??????? Mon, 04 July 2005 02:52 Go to previous messageGo to next message
draven wrote on Sun, 03 July 2005 19:34
do you have to run the boost gauge off a plenum-side vac line or can it be anywhere? Idea
Re: MA61 Vac line - but where does it go to ??????? Mon, 04 July 2005 02:56 Go to previous messageGo to next message
from memory I'm reasonably sure that vac line, if you follow it along the firewall, goes back into the plenum.
Merudo
Central Coast, NSW
February 2005
Re: MA61 Vac line - but where does it go to ??????? Mon, 04 July 2005 03:10 Go to previous messageGo to next message
While it's a different car, i think it may be the same, so ill ask this question-
If I ran a T-piece in the line just before the cruise control actuator, could I fit a boost gauge onto that T piece and still maintain cruise control AND have a functioning boost gauge at the same time?
Will save me from running it all the way from the front of the plenum, that's all.
Re: MA61 Vac line - but where does it go to ??????? Mon, 04 July 2005 03:28 Go to previous messageGo to next message
As long as the line goes straight back to the plenum, and not to a vacuum chamber then yes.
But cruise control actuators, and the heater controls can sometimes go back to a vacuum chamber, so they can still work at WOT and boost.
Merudo
Central Coast, NSW
February 2005
Re: MA61 Vac line - but where does it go to ??????? Mon, 04 July 2005 03:29 Go to previous message
I shall investigate where that line heads then.
Thanks for your advice.
Previous Topic:RA40 manual diff ratio??
Next Topic:AE86 - KE70 What Will.....
Current Time: Fri Oct 23 13:26:54 UTC 2026
Total time taken to generate the page: 0.0050840377807617 seconds
