Toymods » Tech & Conversions » UZZ31 Tranny code 46
UZZ31 Tranny code 46 Sun, 03 July 2005 05:51 Go to next message
Ok, my O/D light is telling me 46 (4 flashes, 2 sec gap, 6 flashes, 4 sec gap)
I cannot find ANYWHERE what this code is.
Anyone got any ideas?
CEL is flashing normally.
MacroP
Binningup WA
Re: UZZ31 Tranny code 46 Sun, 03 July 2005 09:34 Go to previous messageGo to next message
Number 4 solenoid fault, which would be, from memory, is the line pressure PWM solenoid in a A341E.
lextreme.com/Lex%20Autodx.pdf
Good luck.
Re: UZZ31 Tranny code 46 Sun, 03 July 2005 10:20 Go to previous messageGo to next message
Interesting.
This could just be that I am running a UZS131 Crown tranny on a UZZ31 Soarer ecu.
I'm guessing the Soarer uses an A341E and the Crown uses an A340E?
MacroP
Binningup WA
Re: UZZ31 Tranny code 46 Sun, 03 July 2005 10:48 Go to previous messageGo to next message
CrUZsida wrote on Sun, 03 July 2005 18:20
Interesting.
Yes. You can put a power resistor(10Watt) in to the loom to trick the ECU. I wonder how solenoid 3 will operate. In the A340E this is the TC lockup and is either on or off but in the A341E with a Soarer ECU this solenoid in a proportional type with a different impedance though it's still TC lockup. I wonder if the TC lockup will work correctly becuase of this.
Another difference with my A341E vs an A340E I have is that the Soarer box has a forward mounted speed sensor on the right side, post TC on the transmission input shaft after the oil pump. I wonder if this is also needed for the ECU to stop it spitting out a fault code.
MacroP
Binningup WA
Re: UZZ31 Tranny code 46 Sun, 03 July 2005 10:49 Go to previous messageGo to next message
Interesting.
MacroP
Binningup WA
Re: UZZ31 Tranny code 46 Sun, 03 July 2005 10:56 Go to previous messageGo to next message
Interesting.
MacroP
Binningup WA
Re: UZZ31 Tranny code 46 Sun, 03 July 2005 10:58 Go to previous messageGo to next message
Multiple
[Updated on: Sun, 03 July 2005 11:00]
Re: UZZ31 Tranny code 46 Sun, 03 July 2005 10:59 Go to previous messageGo to next message
Hmmmm, 46 was the only code it through.
It manages to select all 4 gears, but kickdown is pretty slow (I could be expecting too much though).
Maybe I'll just get a UZZ31 box, or just an A341E.
Re: UZZ31 Tranny code 46 Wed, 13 July 2005 05:29 Go to previous message
Quick follow up to this
Both the UZZ31 and UZS131 run the A341E tranny.
Both tranny's have the same pinouts.
Tested the box in the car and the spare box I have, both the same
Here is the pinouts.
http://lextreme.com/forums/attachment.php?attachmentid=1761&stc=1
Check the wiring in the loom and it turns out the the B+ for S4 didn't have +12v. So there must be an open circuit somewhere.
So I just wired up B+ for S3 to B+ for S4.
Haven't been able to test drive it yet because I am working on getting SP2 working properly.
Will hopefully drive it later this week.
Previous Topic:Big-end bearing failure with pics - 6 mo since rebuild - any ideas?
Next Topic:Soarer speakers
Current Time: Wed Oct 14 22:39:43 UTC 2026
Total time taken to generate the page: 0.04867696762085 seconds
