Toymods » Tech & Conversions » AFR tuning advice
SW20R
AFR tuning advice Sun, 03 July 2005 13:03 Go to next message
Hi guys
Got my car dyno'd today. 138.6kw stock 2.0L turbo 3SGTE (8psi)
http://img61.imageshack.us/img61/5368/image06dyno5iz.jpg
made pretty good power for a stock motor. Just have tvis disabled (removed the hose) power curve is pretty smooth but the afr. Im thinking of adjusting it with an SAFC-II and maybe better ignition components
AFR dips as low as 10.5 as show on the graph. But averages 11.5-10.5 Rich mixture. Once I sort out intercooling would it be fessable to tune it to get about 12 AFR and hope to get some more power Very Happy
Any advice would greatly be appreciated
Re: AFR tuning advice Sun, 03 July 2005 16:27 Go to previous messageGo to next message
First of all, reconnect the TVIS. By just disconnecting the hose, you've lost all the benefits of the system functioning and you've gained nothing in return. It's there for a reason.
As for tuning the AFR's, take it to someone you know is familiar with the particular tool (i.e. SAFC2) and they should know exactly what to do.
Re: AFR tuning advice Sun, 03 July 2005 16:30 Go to previous messageGo to next message
And to ensure that was seen as the friendly comment it was, Very Happy
SW20R
Re: AFR tuning advice Sun, 03 July 2005 20:04 Go to previous messageGo to next message
Actually I found it to open my top end.
Bottom end is great with tvis enabled. But top end speeds over 100kms. Just takes too long to build up (ie when over taking on the motor way)
Re: AFR tuning advice Sun, 03 July 2005 23:47 Go to previous messageGo to next message
To be honest dude, my money is on it being placebo. Either that or it wasn't working in the first place. Assuming it is working, it would make no more restriction than what you have now, and the only reason I can see it freeing up top end is if you physically removed it.
Re: AFR tuning advice Mon, 04 July 2005 05:34 Go to previous message
TVIS disabled = TVIS at WOT
Previous Topic:20v conversion
Next Topic:Alternators
Current Time: Sat Oct 24 19:59:15 UTC 2026
Total time taken to generate the page: 0.0047380924224854 seconds
