Toymods » Tech & Conversions » 20v conversion on the loose
Leighp
NY
icon6.gif  20v conversion on the loose Mon, 03 June 2002 03:32 Go to next message
Hi all
I am in the process of installing a 20 V (MAP) silver top into a 16v AE 92 SX rolla.
in changing the engine over how hard it is it to do the wiring?? from what i see the 12 pin plug is the only one that seems to need to be modified, bearing that in mind, how do i put/splice
that in with the standard AE 92 loom? Is there any places where i can get the pin outs Eye Spin and wire colour codes for both the 20 v 101 MAP sensor and AE 92 16 v map sensor engine.
is it hard to install A/C or abs, with all the accessories there to do it?? Keeping in mind I was told that ABS needs sensors, is that true?? Freak
Sam
Sydney, Australia
Re: 20v conversion on the loose Mon, 03 June 2002 03:39 Go to previous messageGo to next message
I thought silvertop's were AFM, and blacktops are MAP?
rgrds
sam
ae85 wgtn
NZ
Re: 20v conversion on the loose Mon, 03 June 2002 04:12 Go to previous messageGo to next message
silvertop 4ages are all afm, the ae111 blacktop 20v is the map sensored version.
club4ag and also this site i think have the ecu pin-outs for these engines.
i think it'd be easier to just use the complete loom and ecu from the 20v, which hopefully came with an air flow meter. also i doubt the 16v ecu would be able to run the silvertop to it's potential, if at all.
[Updated on: Mon, 03 June 2002 04:13]
Sam
Sydney, Australia
Re: 20v conversion on the loose Mon, 03 June 2002 05:24 Go to previous messageGo to next message
I agree, use the 20V loom and ECU, then sell me the 100kW loom Up To Something
._T_.
Re: 20v conversion on the loose Mon, 03 June 2002 05:41 Go to previous messageGo to next message
i believe you can actually get a 20v running on a 16v ecu - but no vvt. why bother!
friend can do you a custom loom for your 20v conversion for $550 - make it a really easy conversion!!
T
Leighp
NY
Re: 20v conversion on the loose Mon, 03 June 2002 15:19 Go to previous messageGo to next message
It is a MAP sensor, believe it, i will take a pic for you if you do not believe it, the late model ones (95) got a map sensor, and that is why i am having difficulties.
The loom looks like alot of wires will splice into the 16v loom, but i need help here.
ae85 wgtn
NZ
Re: 20v conversion on the loose Mon, 03 June 2002 21:22 Go to previous messageGo to next message
Freak well that's pretty interesting!
is the engine/loom out of a half-cut or did you get it from another private owner? possibly someone has used a blacktop loom and ecu to convert it to map at some stage.
if it's a 1995 model, which is when the blacktops came out, maybe it's some weird cross-over model that noone's heard of. i'm keen for some pic, not coz i don't believe you just because i've never heard of one before Smile
anyone know of specs for this engine??
Leighp
NY
Re: 20v conversion on the loose Tue, 04 June 2002 00:14 Go to previous messageGo to next message
i will take one today and post it this arvo, it is in a front cut from jap land and i am stoked. Rolling i guess it uses the b/top wiring loom then. no changes, stocko to the airbag that came with it
Leighp
NY
Re: 20v conversion on the loose Wed, 05 June 2002 03:51 Go to previous message
how do i posta pic up on this site????
please help me
Previous Topic:big valve on 4AG and port question?
Next Topic:MR 20v please read
Current Time: Thu Oct 29 18:15:07 UTC 2026
Total time taken to generate the page: 0.0072410106658936 seconds
