Toymods » Tech & Conversions » Intercooler flooded?
ae86slaver
Intercooler flooded? Mon, 04 July 2005 01:16 Go to next message
quick question:
During the heavy rain last week, i took the car out toward bathurst in HEAAVY rain and when i reached there 2/1/2 hours later, it started to sound as if it was running on 3 cylinders, and it definately felt like it as well, no boost, splattering like it couldn't get fuel, sounded like a boxer motor Confused
After frustration set in from checking EVERYTHING, i drove it home and it would not boost/couldn't go over 3000rpm without it jerking/choking. Then about 1 hour from home, it decided to get better and i was boosting again - and the rain wasn't too heavy at that point.
I'm lead to believe that water got into the spark plug holes and interfered with the contact of the 1st cylinder resulting in the 3 cylinder sound.
I took the car out twice on the weekend, and each time (on cold start) it would do the same thing - it was not until a good 45 mins into the drive where it started to boost/run properly.
Could the front mount be flooded with too much water resulting in water in the system?
Or is water in the spark plug holes a good guess?
Re: Intercooler flooded? Mon, 04 July 2005 01:32 Go to previous messageGo to next message
I'd be checking to make sure all the spark plugs are clean and dry. Your intercooler shouldn't be able to get water inside it otherwise it'd be constantly be leaking boost with a hole.
setsuna
Re: Intercooler flooded? Mon, 04 July 2005 01:52 Go to previous messageGo to next message
also check dizzy?
(if it has one Razz)
this happened when I washed my engine one time.
got water in there, and was really crap.
grin.
Skip
Re: Intercooler flooded? Mon, 04 July 2005 01:57 Go to previous messageGo to next message
Is your airfilter wet?
ae86slaver
Re: Intercooler flooded? Mon, 04 July 2005 02:08 Go to previous message
air filter is dry
i have a crank angle sensor, but it is pretty well positioned in the middle of the engine bay so i doubt rain had got to it
Previous Topic:AE86 - KE70 What Will.....
Next Topic:how to get torque converter of ceased engine?
Current Time: Sat Oct 24 01:22:27 UTC 2026
Total time taken to generate the page: 0.0046510696411133 seconds
