Toymods » Tech & Conversions » t25 4age
Ribbo
Northern Beaches
t25 4age Sun, 08 December 2002 13:53 Go to next message
how good would a t25 off a ca18det go on a ge turbo?
or would I be better with the rb ones from the skylines like used in the 4a-gte article
feral4mr2
Bundaberg, Qld.
Re: t25 4age Sun, 08 December 2002 20:51 Go to previous messageGo to next message
Freak my turbo is a t-25 of the ca18det, it works well.... Evil or Very Mad
but i have it on a ze not a ge.....
i think the rb ones are roller or ball bearing?? which would make them a better turbo.....they are of a 6cyl, so i'm not sure if it would be to big? for a ge??
but then again, i think tuneing (as well as research and planning) is the key to being boosted no mater what engine you use.......
Re: t25 4age Mon, 09 December 2002 02:26 Go to previous messageGo to next message
I've used both RB20 and RB25 roller bearing (not the rb20 plain bearing Cefira or r31 turbos), both work reasonably well, although I'm looking at a bit of a hibrid one soon. I'll letcha know how that works..
Ribbo
Northern Beaches
Re: t25 4age Mon, 09 December 2002 07:41 Go to previous messageGo to next message
the ge being higher compression would that have any affect on spooling it up faster?
MR. 2
Parramatta
Re: t25 4age Tue, 10 December 2002 03:45 Go to previous messageGo to next message
nope higher compression wont make it spool faster it will just give your motor more reason to blow up quicker thats the only thing the more comp will do. the more exhaust gasses spin the turbo the more gasses the more spool.
TE72_Turbo
Re: t25 4age Tue, 10 December 2002 12:26 Go to previous messageGo to next message
hmmmmm... I'm not so sure about that one, I reckon higher compression (therefore greater combustion pressures, and higher exhaust gas flow) should result in making boost earlier in the rev range.
I'll have to go away and think about it Smile
any ideas?
MR. 2
Parramatta
Re: t25 4age Tue, 10 December 2002 22:04 Go to previous messageGo to next message
now that i think of it your right i think the high comp may make it spool faster something for me to thinks about to
feral4mr2
Bundaberg, Qld.
Re: t25 4age Tue, 10 December 2002 23:23 Go to previous message
Freak pulcino, has a turbo on his 'ge' aw11..it spools up at virtually the same time as my 'ze'.. go figure?....
air vilocity and probably the size of the turbine wheel housing are the major factor in how early a turbo spools up...that is my understanding of it all....????
it is something to think about though.....
Previous Topic:Turbo swap on 1jz
Next Topic:Hi guyz heen info on MX83 Diff options..mine broken :(
Current Time: Fri Nov 20 05:18:36 UTC 2026
Total time taken to generate the page: 0.0055460929870605 seconds
