Toymods » Tech & Conversions » efi conversion n a sprinter
race4ages
March 2005
efi conversion n a sprinter Mon, 04 July 2005 09:08 Go to next message
im mid way through my 4age into a sprinter nd would like some conformation on a few things before i commence any further.
im up to the fuel system..havent had experience in this so i want some confirmation so i can be at rest!!
im using a VL fuel pump and plan to mount it between the metal fuel lines and fuel tank.Is there enough room here.Where is the ideal place for the pump >>a picture would be great.
also i plan to replace all the rubber hosing.is this needed? or can i just replace the main hose that goes to the fuel pump
i assume that the metal fuel lines can carry the needed amount of fuel to the engine.
lastly can someone give me the model number of the fuel filter i should use.or a picture of your setup??
thanks in advance for any advise/guidance / criticism ..
if you can think of anything that may help in this area please post away
rxbenny
Perth WA
Re: efi conversion n a sprinter Tue, 05 July 2005 14:31 Go to previous messageGo to next message
teh fuel filter in my sprinter with 4age is the same as a twincam ae82
xolent
Re: efi conversion n a sprinter Tue, 05 July 2005 14:45 Go to previous messageGo to next message
I bought some fuel filter called "Cooper" from autobarn. Part number = WZ309
Yes you do have to change all the rubber hoses, if you don't, you'll get a very nice suprise. Be sure to get the right clamps for it too.
Make sure you buy EFI hoses, I bought these "EFI" hoses from this dodgy family-run business in Cabramatta and they broke on me about 4-5 times. Lucky the first 2 times I wasn't far from home, so I risked my ass and drove home to fix it. Now I have spare fuel hoses and clamps in my car just incase it does it again. I recently replaced all of them for the ones I bought at Repco, never had a problem since. $20-ish a metre from what I remember.
Oh yeh, I haven't checked recently but from what I remember, the fuel filter I use, the top and bottom ends are different in size.
Hope this helps.
Re: efi conversion n a sprinter Tue, 05 July 2005 15:41 Go to previous messageGo to next message
intank pump will make your life sooo much easier..
as for EFI filter, toyota ones are good Wink
oh, and buy efi hoses from Enzed or Pirtek.. they are rated higher
[Updated on: Tue, 05 July 2005 15:41]
WHITCHY
Castle Hill
Re: efi conversion n a sprinter Wed, 06 July 2005 14:07 Go to previous messageGo to next message
yep im with oldcorollas...track down an AE82 intank fuel pump, all you have to do is remove the pump, chop the bracket in half, extend it a bit and extend the two wires to suit and then replace the fuel pump in the bracket and it bolts straight where the old 4AC one was!
and if you still have your interior in it is silent! if you don't it is just a quiet whistle that disappears as soon as you take off!
So much easier than chopping fuel lines and creating brackets.
I left my carby fuel lines on at first and they lasted abut 1/2 a day then came off cause I had normal hose clamps too.
Went to pirtek and bought a few metres of efi fuel hose from them and a handfull of efi hose clamps(get enough so you can use 2 clamps on some hoses-the return line is thinner than the other lines) and I havent had a problem since!
if you are staying N/A don't throw valuable conversion money away on a VL pump, should be able to do AE82 conversion for just under 100 beans, including hoses and clamps!
And with fuel filter I just went to my local auto shop with a cutoff of the EFI hose and got an EFI fuel filter with the same size fittings on both ends and used the cutoff EFI hose to get the right size! Just let me know if u want a part number?
Goodluck with ya conversion!
-Whitchy-
davedave
Re: efi conversion n a sprinter Wed, 06 July 2005 22:24 Go to previous messageGo to next message
Good to see you're making progress, you'll have to send me some pics!
I have my aw11 fuel pump still as I replaced mine with a walbro item. If you want to stick $20 in my account I'll post it up.
Dave
Edit: might be worth checking if an aw11 one will fit first, I'd say they'd be the same but best to be sure.
http://mr2.scattered.com.au/image.php?image=IMGP1290.JPG&size=150 It's the one on the left.
[Updated on: Wed, 06 July 2005 22:28]
devolutio
Re: efi conversion n a sprinter Thu, 07 July 2005 02:12 Go to previous messageGo to next message
I used the sv12 camry in tank pump (DON'T!!! the top doesn't fit!!). Yes it is quiet, and yes I did mount it as low in the tank as possible - but it surges horribly for the last 1/4 of the tank.
A friend on the other hand used an in-line pump between the tank and the metal hoses - fucking annoying sound (comes from everywhere), but using the standard 4ac fuel pickup, it only mildly surges after the fuel light comes on (when mine surges the engine looses ALL power).
Just have a look at how many holes and diameter of the standard fuel pickup cap thing before you go buying something from a camry.
http://web.aanet.com.au/devolutio/intank.jpg
as you can see from my pic, you don't need to cut anything, just flatted out the bottom support (or cut it off...) and hoseclamp the pump on at the desired height (use two if you are paranoid) extend the hose and wires and you are done... poke it in the hole, if it fits, lower it, if it doesn't raise it etc.
Re: efi conversion n a sprinter Thu, 07 July 2005 05:10 Go to previous messageGo to next message
davedave wrote on Thu, 07 July 2005 06:24
Hey, thats identical to my Cressida before and after with the walbro.
Down to me putting the brown plug on the factory fuel pump!
race4ages
March 2005
Re: efi conversion n a sprinter Sat, 09 July 2005 10:21 Go to previous messageGo to next message
thanks for the responses
i did first buy an ae82 fuel pump but went with a vl one instead.
this was because i would of had to bend the main fuel line on the pump as it was in the way and the pump could not go in the tank with it in its original shape.
the fuel pump and filter are all in and soon should be able to start the car up and test it....
got to wire up the alternator and the coil and do some work to the throttle linkage
WHITCHY
Castle Hill
Re: efi conversion n a sprinter Sun, 10 July 2005 11:18 Go to previous messageGo to next message
All you had to do with the AE82 pump was cut up all the metal fuel lines from the pump leaving enough room to clamp EFI fuel line over the end and connect it to the existing metal fuel lines.
Ah well if its all in now then no worries!
But if you run a surge tank between tank and VL pump use the 82 intank as a lift pump, that was my original plan but I dont need crazy amounts of fuel and dont suffer from surge so I never got around to fitting the VL pump or surge tank!
Hope it all works out for ya!
Cheers.
-Whitchy-
Gwaijaitat
April 2005
Re: efi conversion n a sprinter Sun, 10 July 2005 13:24 Go to previous messageGo to next message
i'm sorry guys just a few questions.
Is the orginal 4AC fuel pump mechanical or electrical?
Does it mount in the fuel tank or in the engine bay?
I ask coz my fd who is doing the conversion for me thinks the old 4ac fuel pump is mechanical and he says he's planning to mount an external pull type pump in the engine bay about the fuel filter position. He said this would make it easier to fit coz it doesn't require to modify the fuel line.
anyone knows if it should work fine pls help coz I've never heard about this thing or can anyone tell me any good or bad in doing this.
Re: efi conversion n a sprinter Sun, 10 July 2005 13:48 Go to previous messageGo to next message
4AC originally has a rotten little mechanical one on the engine.
On my KE70 I used an old Mazda electric carb pump as a lift pump, made a little swirl pot by welding a couple of ends on a piece of old tailshaft (any piece of 3" pipe will do), used a VL pump to do the main work (actually used an old Cressida one, but it failed from old age, so I replaced it with a new one), used a carby type plastic in line filter before the lift pump, Z200 (I think) EFI filter after the 'main' pump, and a bunch of fittings, hose, etc. from Pirtek. Didn't take long to do, lets me run the car until the tank is bone dry (i.e. if you get any fuel surge, that's it, you're right out), and I didn't have to touch the original tank, lines, hoses, etc. at all.
race4ages
March 2005
Re: efi conversion n a sprinter Mon, 11 July 2005 03:53 Go to previous message
i know realise i was better off using the ae82 rolla pump but didnt want to frig around with lengthing brackets and the like.
my vl pump is held on by an old fuel filter bracket and a fat clamp round the whole works.. will find out soon if it all works!!
damm tafe has started again so ill have to wait till next week to finish my project !
oh yeah in case is doing putting an efi fuel filter in there sprinter i used an sx fuel fiter, mounted in the same location as the old and got the banjo bolts from a wrecker, enzed can supply the other fittings.. pretty simple really..
should have a twin cam sprinter very soon though!
Previous Topic:starting problems, XT133
Next Topic:AE86 Radiator Options
Current Time: Sat Nov 21 19:49:27 UTC 2026
Total time taken to generate the page: 0.011818885803223 seconds
