Toymods » Tech & Conversions » E51 differences?
Corvid
E51 differences? Sun, 08 December 2002 21:44 Go to next message
Hey all,
Just wondering if the later e51 g/b will go into a Aw11 Mr2? if i just swap over the mounts etc.. or are the mounting points different..
I also wanna interchange my LSD Centre..Im guessing thats not a prob?
Please help..
Thanks in advance..
Ben Wilson
Re: E51 differences? Sun, 08 December 2002 22:29 Go to previous messageGo to next message
AFAIK, the gearbox mounts etc are the same, but, the shifter comes in on the wrong side...
Corvid
Re: E51 differences? Sun, 08 December 2002 22:46 Go to previous messageGo to next message
You mean the gear slector input shaft? so it would be facing the back on a Mr2?
Corvid
What did you use Ben?
Ben Wilson
Re: E51 differences? Mon, 09 December 2002 03:04 Go to previous messageGo to next message
I'm currently using my old C-52 until I get a LSD for my E-51..
And if I break it, I've got a spare.
Exactly - Apparently, you can get creative with a big drill and get it to come out the other side if you're feeling brave.
Corvid
Re: E51 differences? Mon, 09 December 2002 03:06 Go to previous messageGo to next message
does the c52 hold up ok???
Hows the traction without lsd?
Corvid
Re: E51 differences? Mon, 09 December 2002 04:00 Go to previous messageGo to next message
Hey Ben,
Also man, Which series GZE you running?
Series 2 with/w-out coil packs? did you do the wiring yourself?
Ben Wilson
Re: E51 differences? Tue, 10 December 2002 01:53 Go to previous messageGo to next message
I'm using an original mr2 ZE motor.
http://members.winnet.com.au/~benw/swap/day12/Laura.jpg
So, the wiring was a piece of piss, just plug in the new loom and go!
The C-52 seems to be holding up OK, it doesn't like being rushed from first to second anymore, but, I get the feeling that I might have a clutch hydraulic problem.
Traction is surprisingly good - my biggest problem off the line is clutch slip, but, I think that might be the hydraulic issue again. Even out of corners, it just tends to squat on the rear wheels and go.
[mikey]
Re: E51 differences? Tue, 10 December 2002 09:04 Go to previous message
Lyle,
I did the opposite,converted MR2 to run FWD selectors, thats the easy part, I dont know how to pull the MR2 selector forks out though without disassembling the box heh... I cut mine off and the GT4 selector forks went straight in without ease.
Michael
Previous Topic:Driveshafts to suit LSD FWD gearbox on 4AGZE
Next Topic:Fuel Gauge
Current Time: Fri Nov 20 05:40:40 UTC 2026
Total time taken to generate the page: 0.010079860687256 seconds
