Classifieds » Parts Wanted » WTB / HELP FINDING AW11 SPRINGS OR COIL OVERS
GUN METAL 87 SC
SYDNEY
WTB / HELP FINDING AW11 SPRINGS OR COIL OVERS Mon, 04 July 2005 13:19 Go to next message
HHHHHHHHEEEEEEEELLLLLLLLLLLP
Where can i gat some coil overs or some decent springs for an AW11 ?
i Dont absolutely need coil overs just so long as i can get some springs with a decent spring rate and ride height.
Unless someone can correct me otherwise the standard rate springs for JDM supercharged AW11s are about 2.2 kg front and about 4.8 kg rear. what i am after is about 3.5 to 4 front and 8 to 9 kg rear. The car is going to be raced both circuit and targa etc so these are the rates i am aiming for. looking at a ride height around 40mm lower than standard.
Does anyone know of any suspension joints prefereably around sydney that can make / source these items or where they can be imported from.
Thanks,
Scott
._T_.
Re: WTB / HELP FINDING AW11 SPRINGS OR COIL OVERS Mon, 04 July 2005 22:53 Go to previous messageGo to next message
scott,
kings should make the appropriate springs for your application.
your estimated rates are *so* close to what i estimated i will need for my aw11 setup!! (either we both got it right, or we ar both equally wrong!) Smile
look at http://www.kingsprings.com.au/Prosport/prosport_li near_rate.htm
springs under 175lb/in are customs, but they are available almost off the shelf!
T
GUN METAL 87 SC
SYDNEY
Re: WTB / HELP FINDING AW11 SPRINGS OR COIL OVERS Tue, 05 July 2005 02:22 Go to previous messageGo to next message
._T_. wrote on Tue, 05 July 2005 08:53
scott,
T
T
Glad to see we are thinking along the same lines
I have seen this site before and they offer a good range of springs. However these are for coil over set ups.
What are you planning to do ? have you allready got coil overs or are you going to get some made up ?
We have to make sure that there is sufficient bump and rebound damping and adjustability of same.
Also many of the coil over set ups i have seen dont offer any camber adjustment like the standards struts do, which if you want asjustability you need adjustable camber tops
._T_.
Re: WTB / HELP FINDING AW11 SPRINGS OR COIL OVERS Tue, 05 July 2005 07:44 Go to previous messageGo to next message
hi scott,
i will make up my own coilover setup, utilising my original strut casings so there is camber adjustment.
as for inserts - probably use tokico externally adjustable shocks
T
GUN METAL 87 SC
SYDNEY
Re: WTB / HELP FINDING AW11 SPRINGS OR COIL OVERS Wed, 06 July 2005 05:34 Go to previous messageGo to next message
T,
Sounds good !
Do you want to make sum up for me while you are there ?? Very Happy
Have you made coil overs before ?
I think this sound like a good idea buti think we need some shorter stroke inderts to limit the droop of the suspension so the coils remain captured with such high rate springs.
Let me know what you think
Regards,
Scott
._T_.
Re: WTB / HELP FINDING AW11 SPRINGS OR COIL OVERS Wed, 06 July 2005 05:46 Go to previous messageGo to next message
scott,
i can make up 2 sets easily enough
yes. not too hard to do with the appropriate equipment!
shorter stroke shocks are always good to have with this sort of setup, but we may not need them (will have to play with a strut to know for sure) about the only company that can make shocks to selected length would be koni..
high rate springs? these are not high rate springs at all!!
500lb+ is getting high rate!
T
GUN METAL 87 SC
SYDNEY
Re: WTB / HELP FINDING AW11 SPRINGS OR COIL OVERS Wed, 06 July 2005 05:58 Go to previous messageGo to next message
Sweet,
so you have done some before.
I allready have adjustable Konis in mine but i dont think the stroke is any shorter than standard, is is possible to shorten them ????
I know what you mean its not really a HIGH rate spring, like some of the sport sedand are running like 1500 pound. But we are talking about an AW11 and something that is still going to be used on the road.
The proposed rates are over double that of the factory.
Whats your number would like to give you a call, actualy i really hate typing Laughing
Regards,
Scott
GUN METAL 87 SC
SYDNEY
Re: WTB / HELP FINDING AW11 SPRINGS OR COIL OVERS Thu, 14 July 2005 06:32 Go to previous messageGo to next message
T,
At last i have got onto a local guy that has built up some coil overs similar to what we were talking about.
He is going to put together some prices to convert the existing struts to coil overs.
He has had a quick look at the car and intended purpose.
he has pointed out it wont be straight forward but can definitely be done.
He is going to have a closer look at the rates we were talking about but thinks they will certainly be pretty close.
He intends on modifying the adjustable konis i have as they are new, will have to shorten the stroke and increase the bump and rebound due to the higher rates we want to run.
He is going to do some measurements and see how much clearance there will be on coils as they will be way lower than stock.
He is also looking at the bumps stop and droop lengths to ensure it all works properly and with a good range of adjustability and rebuildability.
Will keep you informed as i get more info.
Regards,
Scott
panda_levin86
Re: WTB / HELP FINDING AW11 SPRINGS OR COIL OVERS Fri, 15 July 2005 00:05 Go to previous messageGo to next message
Hi boys.
I am about to build myself a set of coil overs for my AW11 as well.
However, I won't be using the AW11 stock struct to do so.
Probably looking at using AE92 or EP92's struct.
(As you boys might have notice, the AW11's struct are TOO wheepy).
If you boys are interested, come down to my workshop and we can further talk about building them !!.
I haven't done mine yet. But I am doing homework about them at the moment. I would like to get some comments from other people as well.
Jim
GUN METAL 87 SC
SYDNEY
Re: WTB / HELP FINDING AW11 SPRINGS OR COIL OVERS Fri, 15 July 2005 00:38 Go to previous message
panda_levin86 wrote on Fri, 15 July 2005 10:05
Hi boys.
Jim
Jim,
Sounds good !
Where abouts in Sydney are you ??
Give me a call on 0403 761 385 would be keen to have a chat, otherwise PM me your contact details.
Regards,
Scott
Previous Topic:WTD: MZ10 Soarer Rims
Next Topic:wanted lsd for sprinter
Current Time: Thu Oct 22 06:54:30 UTC 2026
Total time taken to generate the page: 0.0054478645324707 seconds
