Toymods » Tech & Conversions » 18rg pistons, what kind?
ra40coupe
May 2005
18rg pistons, what kind? Tue, 05 July 2005 09:28 Go to next message
okay, heres my problem.
ive got an 18rg which was "setup for turbo". the compression in all 4 was about 100 across em all. I pulled the head off at work today and noticed they have which look like big domed pistons in them.
I can also see the piston rings down the side of the bore, im pretty sure this shouldnt be.anyone got any ideas?
the reason i pulled the head off was coz it kept backfireing. the head seems okay atm
can anyone identify these? too me they read 8.5 comp?
http://www.members.westnet.com.au/doubleo/piston.jpg
http://www.members.westnet.com.au/doubleo/bore.jpg
[Updated on: Tue, 05 July 2005 09:29]
TurboRG
Nor Calif USA
Re: 18rg pistons, what kind? Tue, 05 July 2005 18:07 Go to previous messageGo to next message
No that a stock RG piston. those are small domes.
for the back firing.
check your Dizzy and the carbs
most likely it your dizzy if it the old points dizzy.
if there no grease on the lobes or old and warn out
it will do that.
Mr DOHC
Re: 18rg pistons, what kind? Wed, 06 July 2005 06:32 Go to previous messageGo to next message
as above
just check the valve seating, this may be causeing backfiring
pistons are usually 20 thou {0.5mm} smaller at the ringlands, so u will be able to see the rings slightly
ra40coupe
May 2005
Re: 18rg pistons, what kind? Wed, 06 July 2005 07:12 Go to previous messageGo to next message
so these are 18RG low comp pistons? being 8.5 comp ration. would this be why i only get 100psi on a comp test.
if this is the case i might be putting in some new pistons as i want a higher ration, what pistons should i look at getting?
Mr DOHC
Re: 18rg pistons, what kind? Wed, 06 July 2005 08:25 Go to previous messageGo to next message
your compression is too low, whats the valve lash set at
joecoolmk2
Re: 18rg pistons, what kind? Wed, 06 July 2005 09:22 Go to previous messageGo to next message
get pistons from a late version of the 18rG, the engine code is 88270-*****. they are higher compression than your's, which is probly an 88253-***** (look on the front of your timing chain cover)
[Updated on: Wed, 06 July 2005 09:23]
blackRA28
adelaide
Re: 18rg pistons, what kind? Wed, 06 July 2005 09:45 Go to previous messageGo to next message
from what i can remember arent 18R-GEU pistons (88270 head) 8.3:1 or 8.4:1 ?
therefore making them not any better than what he has already?
I think you mean the EARLIER 18R-G and 18R-GU pistons, which are higher comp i believe. 88210/88230 has the highest comp pistons. then 88250 etc..
[Updated on: Wed, 06 July 2005 10:48]
joecoolmk2
Re: 18rg pistons, what kind? Wed, 06 July 2005 09:54 Go to previous messageGo to next message
not from what i've heard. 88253 is the lowest at 8.4:1, and the rest are all higher than that.
ra40coupe
May 2005
Re: 18rg pistons, what kind? Wed, 06 July 2005 10:16 Go to previous messageGo to next message
i have an 88230 head with 88210 timing cover. ive got a 250 head which ive been quoted $540 for a reco.
joecoolmk2
Re: 18rg pistons, what kind? Wed, 06 July 2005 10:27 Go to previous messageGo to next message
i feel sorry for you, coz i could do it for practically nothing.
what parts are included in that qouted rebuild?
the 88230 head would be best, where's the rest of the 88210?
ra40coupe
May 2005
Re: 18rg pistons, what kind? Wed, 06 July 2005 10:31 Go to previous messageGo to next message
the 250 head is pretty corroded, needs alot of weldin, has few bents valves.
I bought the car as is, so what was done in the "engine rebuild" or what parts were used is beyond me.
i can get 250 covers and pistons.
jeffro RA28
Tamworth
Re: 18rg pistons, what kind? Wed, 06 July 2005 10:41 Go to previous messageGo to next message
The 210 model of 18rg was the one with 9.7-1 comp. Hence why it was the most powerfull stock of all 18rgs even tho the port casting qaulity is crap. In an effort to regain horsepower because of the lower comp in the later models, they made the valves bigger. Still didnt match the 210.
blackRA28
adelaide
Re: 18rg pistons, what kind? Wed, 06 July 2005 10:46 Go to previous messageGo to next message
THE WITZL wrote on Thu, 13 February 2003 23:31
well.. i have a bit of info on the head numbers on 18R-G's that has helped answer some of my questions....
Quote:
> Here's some head numbers off Al's 18RGs:
> 88250:
> - 49657 single spring early rgu single dump ex ok head small studs on ex
> - 52978 same as above
> 88253:
> - 73086 double spring late rgu good head to start with large studs on ex
duel dump man
> - 62744 single late rgu still good head may be small stud ex should be
single dump
> - 81784 double spring late also
> - 87278 double spring late also
> 88270: these are ale efi heads all double springs alll good heads these
are the ones you use
> - 35140 biggest ports biggest valves no smog ports best casting
> - 08037
> - 49383 very late head newest ive seen
> - 81225 same as above double late rgu if the head is a 11111-88253 not a
11111-88270
> 88253 88270s would be the heads of choice since these need very little
work from the factory these willl make lots of power with little porting
they will make a lot more power with a lot of porting the castings are a lot
thicker around the ports so there is a lot of room
the 88250s can be made good but the ex studs should be changed up to 10mm
ones for best sealing
all of these engines should have 8.5s to 1 but the efi 88270 heads they
should have 8.3 to 1
just be glad you dont have any of those 11111-88230 or 88210 heads they are
good paper weights
hope this helps your info of what you got there sounds like my garage
i think i have 15-18 heads right now
cary
Smile
Re: 18rg pistons, what kind? Wed, 06 July 2005 11:24 Go to previous messageGo to next message
information on the internet varies WILDLY. i dont even believe what i wrote there anymore.....
My current beliefs:
88210 $ 88230 = 9.7:1
8825* = 8.7:1
88270 = 8.3:1
ra40coupe
May 2005
Re: 18rg pistons, what kind? Thu, 07 July 2005 07:13 Go to previous messageGo to next message
well i stripped the motor today, Seem the piston rings were installed wrong. the gap were at the same place. Im guessing im losing some compression here.
my 230 head has alot of corrosion, i place a 250 valve over the 230 valve and they were the same size, guess the 230 has had bigger valves put in.
the 250 head has a few bent valves, but has less corrosion.
what head should i fix up? I was thinbking the 250 with 230 cams?
[Updated on: Thu, 07 July 2005 07:14]
TurboRG
Nor Calif USA
Re: 18rg pistons, what kind? Thu, 07 July 2005 07:50 Go to previous message
THE WITZL wrote on Wed, 06 July 2005 21:24
My current beliefs:
8825* = 8.7:1
88270 = 8.3:1
just get some 20R dome pistons and they will
give you a compression ratio of 9.to1
Previous Topic:AE92 block with bigport head?
Next Topic:SE-86 big brakes finally finished
Current Time: Fri Nov 20 20:34:29 UTC 2026
Total time taken to generate the page: 0.012360811233521 seconds
