Toymods » Tech & Conversions » Twin Pipe design...
kalium
Twin Pipe design... Mon, 09 December 2002 01:32 Go to next message
Hey,
I havent even gotten around to taking the Y pipe off yet, so Im not sure if this is possible at all. In the desing onf the twin pipes, are you able to seperate the wastegate gases from the main dumppipe and then join them back on futhur down the system ?
Re: Twin Pipe design... Mon, 09 December 2002 01:57 Go to previous messageGo to next message
Are you talking about having the exit from the wastegate entering the exhaust after the cat?
What car are we talking about?
Remedy
Southern Sydney
Re: Twin Pipe design... Mon, 09 December 2002 02:01 Go to previous messageGo to next message
Is this another 1J Twin pipe discussion here?
kalium
Re: Twin Pipe design... Tue, 10 December 2002 00:38 Go to previous messageGo to next message
Yep...another 1JZ twinpipe thread.
Like I said, I havent had a close look on the CT12A yet, but on some turbo's it would be possible to design a dump pipe that would seperate the wastegate gas, from the Turbine outlet, and then merely have the wastegate gas re-introduced into the main exhaust before the converter.
This would result in less turbulence around the turbine outlet, and therefore possibly less heat/more power.
Just an thought...
Re: Twin Pipe design... Tue, 10 December 2002 01:38 Go to previous messageGo to next message
I think it would be possible with a suitably shaped dump pipe with a chunk of steel in the middle to separate the flow. Here's a pic of a CT12B which should have similar overall dimensions to what you have:
http://www.turbofast.com.au/img/thousing1.jpg
scottee78
perth
Re: Twin Pipe design... Tue, 10 December 2002 03:29 Go to previous messageGo to next message
it should be possible ... but thats 4 exhaust tubes to manouvere around each other in a confined space as it is .. it will be a mad design if you can pull it off, but if your only using the factory turbo's your boost ceiling is 13-14psi, so i dont think enough of a gain will be had from re routing wastegate gasses .. that is compared to the head phuck of trying to get it all to fit
but hey if you got the time give it a bash, would look awesome if you pulled it off
all IMHO
scottee
edit: i think the biggest challenge is getting the turbine outlets flowing smooth, and not the factory 90 degree bend
[Updated on: Tue, 10 December 2002 03:32]
mx83toy
Re: Twin Pipe design... Tue, 10 December 2002 13:58 Go to previous messageGo to next message
it was done (well simular just using a much shorter seperator) in HPI on the red soara was pretty cool actually
ytri
Preston
Re: Twin Pipe design... Tue, 10 December 2002 22:09 Go to previous messageGo to next message
From memory, didn't the red Soarer in HPI have a 2JZ in it?? Im guessing it would probably be similar though
Guest
Re: Twin Pipe design... Wed, 11 December 2002 00:21 Go to previous message
Someone is doing this right now in newcastle, results should be able to compare to my own twin pipe set up.
it is possible to take the y pipe off without removing the turbo's.
check out celicamad's web site for full instructions.
Count on it taking quite a few hours of knuckle pulping frustration though.
Matt
Previous Topic:RB26DETT (skyline) VS vvti 2JZ-GTE (mkIV supra)
Next Topic:Turbo swap on 1jz
Current Time: Fri Nov 20 05:59:32 UTC 2026
Total time taken to generate the page: 0.0055689811706543 seconds
