Toymods » Tech & Conversions » 7m steel gasket torque
Stomps
Canning Vale WA
7m steel gasket torque Tue, 05 July 2005 11:26 Go to next message
hey does anyone know what to tighten the head bolts to on a 7m-gte with 1.2mm steel gasket??
also do you have to change the head bolts or are they good enough and dont stretch??
if anyone knew the re-tightening sequence that would be good.. cheers
Re: 7m steel gasket torque Tue, 05 July 2005 11:40 Go to previous messageGo to next message
Follow the instructed set out by the gasket manufacturer (unless it says 58ft-lbs)
TheStitt
Membership Secretary
Re: 7m steel gasket torque Wed, 06 July 2005 00:03 Go to previous messageGo to next message
As for the tightenig sequence. Start in the centre and then work outs wards diagonally.
13 14
9 10
3 6
1 2
5 4
7 8
11 12
Hope this helps
Re: 7m steel gasket torque Wed, 06 July 2005 00:36 Go to previous messageGo to next message
Stomps wrote on Tue, 05 July 2005 21:26
They do stretch - this is part of the problem.
I would recommend new factory headbolts or some ARP jobbies. Remember to lube and use the little flat washers so you get the correct torque - vitally important if you don't want to join the "I hate 7MG-BHG" clan.
Stomps
Canning Vale WA
Re: 7m steel gasket torque Wed, 06 July 2005 05:47 Go to previous message
cheers guys, figured they did, useless standard crap..
i have already gone through 2 head gaskets on my old motor (not steel) and my nwe motor came with a standard gasktet Mad
they put in cams, upgraded fuel system and turbo but didnt put in a steel gasket...wankers Mad Mad Mad
Previous Topic:quick 4age Q: timing pulleys
Next Topic:stud for ae86
Current Time: Fri Nov 20 18:26:14 UTC 2026
Total time taken to generate the page: 0.00400710105896 seconds
