Toymods » Tech & Conversions » W-5* shifter bush
KoinTA22
W-5* shifter bush Tue, 05 July 2005 14:14 Go to next message
Hey! Can you change the shifter bush (the ring type one on the selector rail, which the stick goes into) without having to dissasemble the gearbox? and is this bush still available?
-Rod
Henn
Rosanna, Melb
Re: W-5* shifter bush Tue, 05 July 2005 23:51 Go to previous messageGo to next message
Yes, bushes are still available, around $20 all up from Toyota. I think you need to take the whole shifter part off the box to replace these. 6 bolts around where the shifter comes out.
Hen
ed_ma61
Lost in the K hole
Re: W-5* shifter bush Wed, 06 July 2005 00:05 Go to previous messageGo to next message
read the faq at the top of the page, friend
Re: W-5* shifter bush Wed, 06 July 2005 00:36 Go to previous messageGo to next message
If you are talking about the bush that is pretty much part of the gearbox, then no, you can't just buy that from Toyota.
You'd have to buy a whole new shifter elbow thingy.
And the box has to come apart for it to be removed.
ed_ma61
Lost in the K hole
Re: W-5* shifter bush Wed, 06 July 2005 05:17 Go to previous messageGo to next message
whoops, misread...
if you disasemble the rear housing, and take the yoke of the selector shaft, its easy enough to get a (far better) steel bush machined and pressed in.
as glen or myself... we both now have very toight boxes Shocked
KoinTA22
Re: W-5* shifter bush Wed, 06 July 2005 08:06 Go to previous messageGo to next message
Yeah I was thinking it looked like i'd have to pull the back half off the box and remove the thing from the selector shaft. to get the flogged out bush out. I've got one box with a good bush in there but noisy bearings and another box thats quiet but with stuffed bush, might just swap the good bit over if i cant get a bush at short notice...
joecoolmk2
Re: W-5* shifter bush Wed, 06 July 2005 09:31 Go to previous messageGo to next message
if you're talking about the bush for the selector shaft, then all you have to do is swap the rear housings. if you're talking about the nylon ball thing on the end of the gear stick, then that's even easier.
BlackSupra
Re: W-5* shifter bush Wed, 06 July 2005 09:39 Go to previous messageGo to next message
KoinTA22 wrote on Wed, 06 July 2005 18:06
Yeah i had my bush replaced as ed said above.
- Take good box with shagged bush.
- remove rear housing
- There is one 10mm bolt holding the shifter extention arm in place, find it and undo.
- Slide shifter extention arm off the selector shaft.
- Do the same with the other box and just swap the extention arms over.
This will work perfectly assuming the shifter positions are identical between boxes. If they are not identical, then the entire shifter position will need to be changed, or at this point, take the extention arm to a machinist to have a new bush pressed in.
Its UBER toight! Shocked
Re: W-5* shifter bush Wed, 06 July 2005 09:58 Go to previous messageGo to next message
I like glen's new tight box.. much better than the old sloppy one before the surgery.
Re: W-5* shifter bush Wed, 06 July 2005 10:51 Go to previous messageGo to next message
BlackSupra wrote on Wed, 06 July 2005 17:39
You can't remove the rear housing without undoing the 10mm bolt.
Then the shifter extention arm and rear housing come off together.
KoinTA22
Re: W-5* shifter bush Wed, 06 July 2005 12:41 Go to previous messageGo to next message
Sorry guys but where is this bolt? is it one of the many hex keyd bolts?
KoinTA22
Re: W-5* shifter bush Wed, 06 July 2005 13:15 Go to previous messageGo to next message
I removed all 9 bolts holding the two halves together, and the 12mm headed bolt holding the bit with the offending bush to the selector shaft. the halfs are a bit loose, but they won't come apart, whats going on? Mad
Re: W-5* shifter bush Wed, 06 July 2005 13:44 Go to previous messageGo to next message
Nah, don't touch the hex keyed bolts.
Just prise it slowly.
BlackSupra
Re: W-5* shifter bush Thu, 07 July 2005 09:27 Go to previous messageGo to next message
KoinTA22 wrote on Wed, 06 July 2005 23:15
Have you removed the shifter housing and undone the 10mm bolt holding the shifter extention arm in?
wilbo666
Re: W-5* shifter bush Thu, 07 July 2005 11:22 Go to previous messageGo to next message
Have you removed the speedo drive gear?
Drivers side of the box...
Smile
KoinTA22
Re: W-5* shifter bush Fri, 08 July 2005 02:42 Go to previous messageGo to next message
Okay I got it apart, just neededa bit of a thump and prize!
Re: W-5* shifter bush Fri, 08 July 2005 02:50 Go to previous messageGo to next message
KoinTA22 wrote on Fri, 08 July 2005 10:42
What did it win?
Re: W-5* shifter bush Fri, 08 July 2005 05:03 Go to previous messageGo to next message
Slightly off topic, but for the last few weeks I've been driving around with no shifter bushes (at all) in my W58. Every gear change is an adventure!
Re: W-5* shifter bush Fri, 08 July 2005 05:07 Go to previous message
That gives new meaning to the term 'sloppy seconds'
Previous Topic:AE86 Tie Rods, Control Arms, ETC
Next Topic:Looking for 4agze afm part number
Current Time: Sat Oct 31 13:03:38 UTC 2026
Total time taken to generate the page: 0.11819100379944 seconds
