Toymods » Tech & Conversions » 4A-GZE Rebuild
AE92-4AGZE
Rockhampton, Queensland
July 2005
4A-GZE Rebuild Tue, 05 July 2005 14:26 Go to next message
Hello all,
i have done a search for this topic and found a few things on here, but they didnt help me very much.
I am chasing a rebuild kit for a 4A-GZE engine that i have in my AE92 Corolla. I want everything except pistons. Can anybody point me in the right direction please?
Also i am chasing an English service and repair manual for these engines? any ideas?
Many thanks in advance!
Big T
Re: 4A-GZE Rebuild Tue, 05 July 2005 14:57 Go to previous messageGo to next message
When you say "everything" what does that actually mean? Are you including things like valves, shims, valve bushings, oil pump, etc etc?
Or do you just mean a seals/gasket kit + piston rings?
jackel
Re: 4A-GZE Rebuild Tue, 05 July 2005 15:39 Go to previous messageGo to next message
http://www.swmotorsport.com/enginegskt.htm
gaskets
feral4mr2
Bundaberg, Qld.
Re: 4A-GZE Rebuild Tue, 05 July 2005 21:28 Go to previous messageGo to next message
most auto spare parts shops should be able to get you aftermarket rings, bearings, and a full gasket kit etc.
good luck finding a manual for the 4agze. all you'll need is a 4age one anyways, the rebuild procedure is the same for both engines.
GTZLevin
Gold Coast/Brisbane/No wh...
January 2005
Re: 4A-GZE Rebuild Tue, 05 July 2005 23:20 Go to previous messageGo to next message
in my recent rebuild i have the head and bottom end reconditioned...
bottom end honed and bored for better flow..
balanced and lightened crank..
new, forged and shot peened rods
new wisco low comp pistons
new gasket kit
new custom built clutch
new plugs and leads
new air filter
and ll the other things like flushing the radiator have the a/c regassed etc...
(NOW BRING ON THE TURBO)
lol
kingmick
Banned by his request
moved to tamworth
Re: 4A-GZE Rebuild Wed, 06 July 2005 06:14 Go to previous messageGo to next message
so you need a full gasket set, top and bottom,bearings for big and small end,head service,block machined,rings{why dont you need pistons?},waterpump,welsh plugs,new clutch if its below about half useable,especially in a FWD car,timing belt set,oil and fuel filters,engine and diff oil,coolant, radiator , thermostat,set of plugs,air cleaner if not a K&N etc and you might aswell change the power steering fluid and flush the brake fluid if it hasnt been done.
mick
p.s anyone that needs to regas a aircon unit in a roll or a ae86 when doing a rebuild,shouldnt be a mechanic and or they are charging you for something that isnt really done.
[Updated on: Wed, 06 July 2005 06:17]
GTZLevin
January 2005
Re: 4A-GZE Rebuild Wed, 06 July 2005 08:41 Go to previous messageGo to next message
thanks for the heads up..
yeah i forgot to mention all the other stuff..
seals, oils, gaskets, bearings, end bearings etc..
AE92-4AGZE
July 2005
Re: 4A-GZE Rebuild Thu, 07 July 2005 03:39 Go to previous messageGo to next message
thanks for the feedback guys, yes i am doing a full rebuild and i have a set of good pistons already. Does anyone do a rebuild kit for these engines? or does anyone know of a good place to order all my parts that i will need from? i am getting any machine work done locally so that is not a drama.
another thing i noticed, the stock pistons from Toyota are only $99 each?
And if i cant find a manual for the 4A-GZE engine, then where do i grab one for a 4A-GE engine? or are they easily obtainable?
Big T
Re: 4A-GZE Rebuild Thu, 07 July 2005 11:38 Go to previous message
I have a set of brand new GZE pistons for sale atm if you need some.
http://forums.toymods.org.au/index.php?t=msg&t h=72879&start=0&rid=7123&S=917e30a6f5f 4b2afc700c4e53f370921
I've got a 4age rebuild manual that i bought privately off these forums but i'm pretty sure there's one in the "articles" section of the toymods website too.
Eddie.
Previous Topic:why does my fuel guage fluctuate...electrical?
Next Topic:BSFC
Current Time: Fri Nov 20 21:52:02 UTC 2026
Total time taken to generate the page: 0.079916000366211 seconds
