Toymods » Tech & Conversions » Pilot Bearing in rwd 4AGE with w5* box
Big T
Pilot Bearing in rwd 4AGE with w5* box Wed, 06 July 2005 00:08 Go to next message
Hey all. I'm just curious to know what people have done with the pilot bearing that holds the input shaft of the gearbox in place?
I'm not sure if it fits onto a w5* box seeing as the input spline is chunkier. Does anyone know if it fits?
Eddie.
Steve-AE86
Ademelaide, SA
Re: Pilot Bearing in rwd 4AGE with w5* box Wed, 06 July 2005 01:58 Go to previous messageGo to next message
i take it by pilot bearing you're talking about the spigot bearing.
if thats the case, they're the same. Wink
ae86slaver
Re: Pilot Bearing in rwd 4AGE with w5* box Wed, 06 July 2005 02:40 Go to previous messageGo to next message
just measure up the input shaft/flywheel tunnel and your clutch place should be able to find a few bearing sizes which would suit
have the tool handy as well for removing it - theres hardly any other way of removing it without it Confused
Steve-AE86
Ademelaide, SA
Re: Pilot Bearing in rwd 4AGE with w5* box Wed, 06 July 2005 03:08 Go to previous messageGo to next message
the input spline section is chunkier, but the end of the input shaft on the w5* box is the same as a t50.
so unless there's something drastically wrong with the spigot bearing jammed in the back of your 4A crank, then just use the one you've got.
steve
Big T
Re: Pilot Bearing in rwd 4AGE with w5* box Wed, 06 July 2005 03:15 Go to previous messageGo to next message
Thanks dudes. Well i'll have to get it out of the block in the car atm cause i'm using a different bottom end. Maybe i should just order another one... sounds easier that way.
Eddie.
ae86slaver
Re: Pilot Bearing in rwd 4AGE with w5* box Wed, 06 July 2005 03:26 Go to previous messageGo to next message
yeah definately replace it if you can
Smile
Re: Pilot Bearing in rwd 4AGE with w5* box Wed, 06 July 2005 03:56 Go to previous messageGo to next message
For the sake of the couple of dollars they are, just replace it with a new one, as well as the release bearing, and everyone'll be happy. If the shaft won't fit in the bearing, it's because someone's furred up the end of it and it needs cleaning up and a tiny bit of grease smeared onto it.
Big T
Re: Pilot Bearing in rwd 4AGE with w5* box Tue, 12 July 2005 10:18 Go to previous messageGo to next message
Sorry to bump this but i've been looking through the EPC for the bearing but want to confirm.
I'm pretty sure it's this thingy but would like to be sure. It comes under the "Powertrain/Chassis Group" in the EPC for a jdm AE86.
Part no: 33131-14020-
Part name: RETAINER, BEARING, FRONT (MTM)
Cheers guys.
Eddie.
rthy
Melbourne - NthSubs
Re: Pilot Bearing in rwd 4AGE with w5* box Tue, 12 July 2005 12:30 Go to previous messageGo to next message
where can you get these bearing from?
ae95
Re: Pilot Bearing in rwd 4AGE with w5* box Tue, 12 July 2005 12:40 Go to previous messageGo to next message
toyota
you'll have a hard time getting it out in one piece. most people machine them out and then refit a new one.
if your using a different bottom end id suggest buyting one new and whacking it in
Steve-AE86
Ademelaide, SA
Re: Pilot Bearing in rwd 4AGE with w5* box Tue, 12 July 2005 12:43 Go to previous messageGo to next message
any bearing shop, be it Gardner Bearings, CBC, etc will have a listing for them.
you go in there, and ask for a spigot bearing for an AE86 Toyota Sprinter, 1985 model.
they'll charge you about $7, and give you a bearing.
to get the old one out, use a hammer, a screwdriver, or whatever you can to get it out. makes no difference.
to put the new one in, get a 20mm socket, and a hammer, and bash teh fucker in.
it's not rocket science.
psychofox
Wollongong, NSW
Re: Pilot Bearing in rwd 4AGE with w5* box Wed, 13 July 2005 04:01 Go to previous message
I got one from a bearing specialist for $4.50. It's a sealed 6001 (FAG) bearing. Common as anything the bloke said.
Previous Topic:Soarer speakers
Next Topic:Removing AC in an st162
Current Time: Fri Nov 20 17:54:17 UTC 2026
Total time taken to generate the page: 0.0055949687957764 seconds
