Toymods » Tech & Conversions » SE-86 big brakes finally finished
Bill Sherwood
Brisbane / Gold Coast
SE-86 big brakes finally finished Wed, 06 July 2005 07:39 Go to next message
I'm being cheeky and have decided to call it an SE-86 from now on. Smile
The big brakes are on, yet to be bled and driven.
http://www.billzilla.org/ae86bigbrake1.jpg
The difference between the standard AE-86 disc and the big one.
http://www.billzilla.org/ae86bigbrake2.jpg
Test fit on the strut.
http://www.billzilla.org/ae86bigbrake3.jpg
16" wheel, still plenty of room left.
http://www.billzilla.org/ae86bigbrake4.jpg
No backing plate, so I have to keep some temps in the brakes in puddles.
Toyota RAV4 discs, 300m diameter 19mm thick & ventilated, Wilwood Dynalite four-spot cailpers, milled backing plate from a large chunk of alloy.
Fingers crossed it'll work well.
Re: SE-86 big brakes finally finished Wed, 06 July 2005 07:52 Go to previous messageGo to next message
looks like you have a nice moment arm there!
how much of the inner part of the disc is not being used? (not that you need massive pads on a light car with large discs anyway Wink )
nice work Smile
Bill Sherwood
Re: SE-86 big brakes finally finished Wed, 06 July 2005 07:55 Go to previous messageGo to next message
oldcorollas wrote on Wed, 06 July 2005 17:52
nice work Smile
You can't see the inside of the disc there, but the inner section of the pad is right on the edge. So's the outer edge, so it's almost as if the pads & calipers were made for those discs. Pretty handy!
Bill Sherwood
Re: SE-86 big brakes finally finished Thu, 07 July 2005 00:05 Go to previous messageGo to next message
FWIW here's the mounting bracket, milled from a large chunk of alloy.
http://www.billzilla.org/ae86bigbrake5.jpg
Re: SE-86 big brakes finally finished Thu, 07 July 2005 06:08 Go to previous messageGo to next message
Looks tidy.
I ummed and arred about those rotors for another (similarly light) application. Were you able to get undrilled blanks?
Bill Sherwood
Re: SE-86 big brakes finally finished Thu, 07 July 2005 06:44 Go to previous message
gianttomato wrote on Thu, 07 July 2005 16:08
Looks tidy.
Nope, unfortunately not.
Just got back from its first drive.
Not very good to start with, but the fronts are starting to wake up.
I only gave it a half-arsed bleed to get some pedal so I'm not really surprised it's not the best. But as the pads settle it's getting better.
Initally I could only lock the rears, so I would on more front brake because I didn't really know where the balance bar was set anyway.
It's now fully at the front and I can lock the fronts with a bit of effort.
I think once the pads are finally settled and all the air is out of the system I can wind off a heap of front balance bar, and it'll have a really nice pedal and pull up well.
Anyway, the discs are nice & shiny now. Smile
Previous Topic:18rg pistons, what kind?
Next Topic:AE92 Seca Rear drum adjustment?? anyone know how?
Current Time: Fri Nov 20 19:54:56 UTC 2026
Total time taken to generate the page: 0.15231204032898 seconds
