Toymods » Tech & Conversions » metal headgaskets, why bother?
Sam_Q
S.E suberbs, Vic
metal headgaskets, why bother? Wed, 06 July 2005 10:07 Go to next message
I untill recently was going to get myself a thin metal head gasket for my silver 20V to raise the compression, now from what I hear I need to deck the block before I use one. Does this mean machine it flat?
I am wondering if I need to do machining anyway why not just machine the head down to raise the compression and use a normal gasket?
-how much does the compression get raised to with a 0.7mm gasket anyway?
-will it seal without machining if I use that Hylomar spray?
-perhaps I am asking the wrong thing altogether, is it worth fitting these at all from a power/economy point of view?
berad
Re: metal headgaskets, why bother? Wed, 06 July 2005 11:01 Go to previous messageGo to next message
cant help you with the compression, but i know a few people who have just replaced the head gasket and have had no problems but saying that they dont tell you to deck it etc for no reason.
Sam_Q
S.E suberbs, Vic
Re: metal headgaskets, why bother? Wed, 06 July 2005 11:42 Go to previous messageGo to next message
do you know if they used a thinner than standard gasket?
kingmick
Banned by his request
moved to tamworth
Re: metal headgaskets, why bother? Wed, 06 July 2005 12:10 Go to previous messageGo to next message
you deck the block to make sure it is perfectlly flat as you would do for a normal gasket if it needed it and shaving the head and or block if it only needs a thin skim makes sweet FA difference to comp ratio.metal head gasket is the way to go in a NA motor if you use high comp pistons or if you turbo or superchage it.for a stocker motor dont bother just use a standard gasket.then the next set is copper headgasket and oring with a receiver.
mick
Sam_Q
S.E suberbs, Vic
Re: metal headgaskets, why bother? Wed, 06 July 2005 12:21 Go to previous messageGo to next message
whats it cost and who does it? when I was talking about raising the compression ratio I was talking about either a thinner gasket or shaving the head. Come to think of it I never have heard of anyone shaving a 20V head.
GefGef
January 2005
Re: metal headgaskets, why bother? Thu, 07 July 2005 04:51 Go to previous messageGo to next message
You've never heard of it cause it's a silly thing to do. One of the reasons 20Vs go so hard-apart from the obvious- is cause they already have super high compression. Why do you think you have to run high octane fuel in them? Apart from that if you shave the head too much or or put too thin a head gasket on there you'll put the cam timing out of wack, which would have a much greater effect for the worse than any benefit, if at all, that you'd get from the very small increase in compression that you'd get.
Geoff
Sam_Q
S.E suberbs, Vic
Re: metal headgaskets, why bother? Thu, 07 July 2005 06:50 Go to previous messageGo to next message
being a silly reason usually doesnt't stop a large amount of people. Anyhow you have a point, I think the gains wouldnt be worth the cost. I will stick to my standard gasket and run some extra timing instead.
RWDboy
Re: metal headgaskets, why bother? Thu, 07 July 2005 07:23 Go to previous messageGo to next message
Most people probably don't shave off much from 20V heads because the valves probably get in the way - I imagine you shave off more than 20 thou you'd probably start to hit valve seats. I know that's the case for 3S-GE heads (although admittedly I'm sure that the 4A-GE 20V head is significantly different, there is still only so much room).
The change in compression ratio won't be worth it though...you are much better off getting some *good* high compression pistons (pref. aluminium for reciprocating mass reasons) if you want to chase big hp out of the motor.
Sam_Q
S.E suberbs, Vic
Re: metal headgaskets, why bother? Thu, 07 July 2005 07:43 Go to previous messageGo to next message
seeing that all 4age's are a non interferance engine I doubt it would change anything. Otherwise a good point. I wonder how much the wear rate would increase from 10.5:1 to 11.5:1?
takai
Re: metal headgaskets, why bother? Thu, 07 July 2005 08:31 Go to previous messageGo to next message
Actually as soon as you go over 8.5mm lift on the cams, or remove more than 1mm from the head most 4As become interference engines anyway.
Sam_Q
S.E suberbs, Vic
Re: metal headgaskets, why bother? Thu, 07 July 2005 10:08 Go to previous messageGo to next message
what I meant was that because they are initually a non interference engine it would take a shitload to make the valves hit the pistons under normal circimstances
takai
Re: metal headgaskets, why bother? Thu, 07 July 2005 10:19 Go to previous messageGo to next message
True
Sam_Q
S.E suberbs, Vic
Re: metal headgaskets, why bother? Thu, 07 July 2005 10:26 Go to previous messageGo to next message
hey Chris where did you get your gasket from and how much did it cost?
takai
Re: metal headgaskets, why bother? Thu, 07 July 2005 10:34 Go to previous messageGo to next message
Toyota, like $75ish.
Sam_Q
S.E suberbs, Vic
Re: metal headgaskets, why bother? Thu, 07 July 2005 11:12 Go to previous messageGo to next message
I thought you had a metal headgasket?
takai
Re: metal headgaskets, why bother? Thu, 07 July 2005 11:26 Go to previous messageGo to next message
I do, i have a TRD 0.8mm.
Sam_Q
S.E suberbs, Vic
Re: metal headgaskets, why bother? Thu, 07 July 2005 12:17 Go to previous messageGo to next message
do you by any chance have a part number for that? also how much does it raise the compression?
Big T
Re: metal headgaskets, why bother? Thu, 07 July 2005 12:40 Go to previous messageGo to next message
They actually have a 0.5mm one as well. Might be worth a thought.
Gasket,cylinder head: 11115-AE814 t=0.8mm
Gasket,cylinder head: 11115-AE824 t=0.5mm
$75 is an awesome price for a new TRD hg too. Cheapest I've been quoted at was $104 and i thought that was a bargain. I've been quoted up to $140 from different places.
Eddie.
RWDboy
Re: metal headgaskets, why bother? Thu, 07 July 2005 13:42 Go to previous messageGo to next message
Sam_Q wrote on Thu, 07 July 2005 17:13
I think you slightly missed my point - what I mean is that as you start machining the cylinder head, the edges of the combustion chamber will start to 'shrink' (as it is shaped like a dome) and you will most likely get (very quickly) to a point where you will be machining back the valve seats etc as the combustion chamber has shrunk to a point where the valves no longer 'fit in' to the shape.
Sam_Q
S.E suberbs, Vic
Re: metal headgaskets, why bother? Thu, 07 July 2005 13:55 Go to previous messageGo to next message
RWDboy: oh ok, it is easy to forget about the squish area and seats, I thought they were further set back though?
so guys any idea what a TRD 0.8mm gasket might bump my compression up to?
oh I just remembered, are these for a 16V? people tell me theres a difference.
[Updated on: Thu, 07 July 2005 13:56]
Big T
Re: metal headgaskets, why bother? Thu, 07 July 2005 14:28 Go to previous messageGo to next message
Sorry mate... forgot you had the 20v. The ones i posted just before are for a 16v.
Gasket,cylinder head 11115-AE001 t=0.8
That's the one for the 20V. They don't have the 0.5mm option for them. I think these are a bit more expensive too.
Don't know about the compression rates though.
Eddie.
[Updated on: Thu, 07 July 2005 14:29]
demuire
Ipswich
Re: metal headgaskets, why bother? Thu, 07 July 2005 23:37 Go to previous messageGo to next message
$75ish? Wow, that's cheap...
Sam_Q
S.E suberbs, Vic
Re: metal headgaskets, why bother? Fri, 08 July 2005 07:00 Go to previous messageGo to next message
thanks Big T, for that price i might as well get one. I will call a few places up.
Sam_Q
S.E suberbs, Vic
Re: metal headgaskets, why bother? Thu, 28 July 2005 11:46 Go to previous messageGo to next message
I ended up ordering mine for $104 from greenline. I think thats pretty cheap for a 20V gasket of any kind let alone a TRD metal one.
RWDboy
Re: metal headgaskets, why bother? Thu, 28 July 2005 13:13 Go to previous message
Oh - btw in case you forget, when you shave off material from the head, or get a thinner head gasket, you will put your cam timing out by a fraction! Maybe get some adjustable cam pulleys to sort that out.
Previous Topic:4age chip
Next Topic:Installing Haltech e6x - 4age
Current Time: Thu Oct 29 07:15:38 UTC 2026
Total time taken to generate the page: 0.12135195732117 seconds
