Toymods » General Car Talk » 7m AFM
Spence
January 2005
7m AFM Thu, 07 July 2005 10:16 Go to next message
hey
can anyone tell me the numbers on the 7m turbo air flow meter. my car doesn't have one and i need to get one. i need the numbers to make sure i get the right one. its for a ma70 supra.
Spence
Re: 7m AFM Thu, 07 July 2005 10:47 Go to previous messageGo to next message
Gen2 AFM - 22204-42010
ECU number - 89661-14230 (Automatic ECU)
EvilJack
Sutho/Hills NSW
Re: 7m AFM Thu, 07 July 2005 10:50 Go to previous messageGo to next message
EPC Says 22250-42020 for 7MGTE
Spence
January 2005
Re: 7m AFM Thu, 07 July 2005 11:05 Go to previous messageGo to next message
its an 89 model with manual. does it matter that much between models?
Re: 7m AFM Fri, 08 July 2005 00:51 Go to previous messageGo to next message
You have to get it to match the ECU.
Re: 7m AFM Fri, 08 July 2005 00:55 Go to previous messageGo to next message
You might not even need one if the car isnt running on the factory ecu.
Spence
January 2005
Re: 7m AFM Fri, 08 July 2005 02:03 Go to previous messageGo to next message
yeah but i've found out that its only running a piggy back and for some reason its not running. which number would be the right number?
Re: 7m AFM Fri, 08 July 2005 02:07 Go to previous messageGo to next message
Whats the ECU part number?
Spence
January 2005
Re: 7m AFM Fri, 08 July 2005 02:48 Go to previous messageGo to next message
not sure i still haven't seen the car yet. all i can tell you is that its a 89 ma70 manual 7m turbo.
just sent off an email to try and get it.
Spence
January 2005
Re: 7m AFM Mon, 11 July 2005 04:12 Go to previous messageGo to next message
got the ecu part numbers:
89661-24100
175000-0571 12V
which AFM goes with this ecu??
Spence
1200det
Re: 7m AFM Mon, 11 July 2005 04:19 Go to previous messageGo to next message
If its the 400 odd hp Supra in your signature that one would me map sensed i would think via a HKS VPC ? Or Turbo A ecu
Spence
January 2005
Re: 7m AFM Mon, 11 July 2005 04:24 Go to previous messageGo to next message
its got a hks fconv piggy back. is that what you mean? we're going to pull it off and run it as if it was stock with a bit more boost cause of the bigger turbo. we'll run the boost controller at the lowest. i just want to get it running Sad
Spence
1200det
Re: 7m AFM Mon, 11 July 2005 06:31 Go to previous messageGo to next message
Does it have larger injectors ? If it does the standard AFM and ECU wont be pretty with the air/fuel ratios Smile
Spence wrote on Mon, 11 July 2005 14:24
Spence
Spence
January 2005
Re: 7m AFM Mon, 11 July 2005 07:42 Go to previous messageGo to next message
its got hks 430cc main injectors with additional pair of 380cc with a hks aic so i assume i can control the amount of fuel that goes in so i can bring that back to almost stock.
i think i'll have to start saving for a standalone ecu Sad $$$
Spence
1200det
Re: 7m AFM Mon, 11 July 2005 07:52 Go to previous messageGo to next message
Ahhhh yeah with the cpntroller you will be ok
I cant understand why they would goto HKS 430cc when factory is 440cc
Spence wrote on Mon, 11 July 2005 17:42
Spence
BlackSupra
Re: 7m AFM Mon, 11 July 2005 07:59 Go to previous messageGo to next message
Good luck tuning it all if there is a problem!
Spence
January 2005
Re: 7m AFM Mon, 11 July 2005 08:38 Go to previous messageGo to next message
apparently the problem is only with the hks piggy back unit or with its wiring.
BlackSupra
Re: 7m AFM Mon, 11 July 2005 08:43 Go to previous messageGo to next message
Spence wrote on Mon, 11 July 2005 18:38
with its wiring.
Hahahaha
Have you looked at the wiring job, if it is anything like mine was, it is 100% rubbish and would probably be quite hard to determine what the wiring issue is.
Spence
January 2005
Re: 7m AFM Mon, 11 July 2005 08:46 Go to previous messageGo to next message
nah haven't even seen the car yet, its still in brisbane. from the pics i've got the wiring is much tidier than yours hehe
BlackSupra
Re: 7m AFM Mon, 11 July 2005 08:48 Go to previous message
All i can say is, pull out the units and have a look.
Mine is much tidier now Smile
Previous Topic:THE NEXT WRX!!
Next Topic:spotted turbo ma61
Current Time: Thu Oct 22 05:04:08 UTC 2026
Total time taken to generate the page: 0.0054929256439209 seconds
