Toymods » Tech & Conversions » water in engine
Mr DOHC
water in engine Mon, 09 December 2002 11:34 Go to next message
i left my engine outside just now on a trailer
and din't realise it was raining
water got in the carbs and exhaust ports
its an 18RGU
what can i do to remove all the water without costing alot if any cash
Bugman
Re: water in engine Mon, 09 December 2002 11:42 Go to previous messageGo to next message
put it inside and let it evaporate
Esteban
Brisbane - Chapel Hill
Re: water in engine Mon, 09 December 2002 23:00 Go to previous messageGo to next message
an air compressor used liberally will speed up the drying out process ...
juzzo84
Hornsby, N.S.W
icon10.gif  Re: water in engine Tue, 10 December 2002 19:55 Go to previous messageGo to next message
it will not cause any real damage, just make sure it is all removed or dried out before you attempt to run the motor in the car.
JUZZO
[Updated on: Tue, 10 December 2002 19:55]
Sprocket
The Central Coast
Re: water in engine Wed, 11 December 2002 05:41 Go to previous message
I wouldn't recommend just letting it evaporate, it'd probably rust the bores if it got inside one of the cylinders (theoretically one of the valves has to be open)
Depending on how much water got in, turn the motor upside down first, let whatever rained in, slip out.
Compressed air in a spark plug hole sounds good, you'll find which one has water in it pretty easily.
After that I'd suggest spraying WD40 liberally into the bore with water to disperse it.
Then before you start the motor, put a small squirt (just a couple of drops) into each bore 30mins before you crank her over.
Should get rid of all rust and water no worries. (remember some people run around with cars with blown head gaskets with small amounts of water in the bores for weeks!)
My 2 cents Smile
Previous Topic:wiring diagram
Next Topic:URGENT: throttle setup for 18r-geu RA23
Current Time: Sun Sep 13 10:19:05 UTC 2026
Total time taken to generate the page: 0.058758020401001 seconds
