Toymods » Tech & Conversions » Welding etc
djb23_20v
Wollongong
icon5.gif  Welding etc Mon, 09 December 2002 11:37 Go to next message
Guys,
A query about welding: I want to fabricate material like thin aluminium or steel (2mm or 3mm plate) into items such as catch cans, intercooler components, exhausts bits etc.
Can you perform this kind of work with an oxy welding kit? I have a MIG which is great for thickish plate, but when used on Aluminium melts straight through, even on lowest current settings.
What do you guys use for such work?
Dan
FLY PSI
icon4.gif  Re: Welding etc Mon, 09 December 2002 12:02 Go to previous messageGo to next message
I recomend a TIG for welding thin material. i work in a sheetmetal work shop and i know that is the way to go. Ive never tryed useing an oxy for Aluminium! but i do know that an oxy weld has a lower temp tolarance. a mig is only good for tacking of thin aluminium but not to good for long welds as it just melts the metal.
djb23_20v
Wollongong
Re: Welding etc Mon, 09 December 2002 12:30 Go to previous messageGo to next message
Yep, I figure TIG is the way to go. But if I can get away with an oxy which also lets me do heaps of other stuff, I'd rather get the oxy.
Has anyone tried using an oxy on thin sections?
E30-323ti
Re: Welding etc Mon, 09 December 2002 20:50 Go to previous messageGo to next message
For welding thin alum with oxy I think you can use LPG instead of acetilne(sp), as it burns cooler, and something about putting soap on the area you are going to weld, something to do with the oxide coating on the alum.
Use A TIG!!
Esteban
Brisbane - Chapel Hill
Re: Welding etc Mon, 09 December 2002 22:55 Go to previous message
Yeah, I'll use a TIG when someone buys me one ... whats the point of doing your own welding in the first place?? ":)
Previous Topic:ae86 aftermarket side mirrors
Next Topic:4age bluetop wiring diagram
Current Time: Fri Nov 20 06:50:23 UTC 2026
Total time taken to generate the page: 0.0038049221038818 seconds
