Toymods » Tech & Conversions » 7mgte
paulw85
Campbelltown
February 2005
7mgte Thu, 07 July 2005 13:54 Go to next message
its looking like ive got the dreaded bhg, im getting a compression test done tommorow...
im thinking of getting a 7mgte + computer + loom... what would be involved in getting it all working, im just about sure the engine should physically fit into the cressida, its just the wiring.
ill also probably get a new hg from toyota and re torquing it to a higher setting.
can it keep the same transmission too?
any other things i should watch out for?
TheStitt
Membership Secretary
Re: 7mgte Thu, 07 July 2005 22:40 Go to previous messageGo to next message
What cressi have you got MX73 or MX83?? either way both had M engines in them and the 7MGTE will bolt straight in.
Getting it all working is a hard question. Espically when it comes to fuel system. You could bolt it all in and run standard 5MGE/7MGE fuel pump and no real issues, you would need to get a better fuel pump if you wanted to start running big boost etc.
As for wiring that is basically your biggest prob, talk to ppl like side show or an auto elec about getting it wired in.
The stardard gear box will bolt up its just a matter of power, I'm not sure on the differences if any between turbo and non turbo boxes, however I suspect toyota being toyota the standard box would be able to put up with the power of standardish 7MGTE.
If you wanted to build the motor so you wouldn't have to worry about more BHG's I would get a metal gasket and get some ARP studs. It will be set and forget with no more issues.
Other things to watch will just be little things, things possible not fitting in the engine bay the3y way the used to, due to turbo, different inlet's just small stuff which is easy to over come.
TRD_Supra
On Probation
Hobart
Re: 7mgte Fri, 08 July 2005 02:47 Go to previous message
just remeber to fix obvious shit like the water pump etc etc
Previous Topic:Injector Duty Cycles
Next Topic:Mounting of Celicamad/Hiperboost boost controller ???
Current Time: Fri Oct 30 05:26:20 UTC 2026
Total time taken to generate the page: 0.08655309677124 seconds
