Toymods » Tech & Conversions » Gen3 3SGTE Differences
smt_007
icon14.gif  Gen3 3SGTE Differences Thu, 07 July 2005 14:46 Go to next message
What are the differences between the gen3 3sgte in the mr2 and the gt4?, i know the mr2 doesnt have the water cooler anything else?.
Cheers.
[Updated on: Fri, 08 July 2005 01:05]
RAV-GT4
Toymods member
Rydalmere, NSW
Re: Gen3 3SGTE Differences Fri, 08 July 2005 03:32 Go to previous messageGo to next message
They are largely the same engine... they have the same computers to run them, same size injectors, same Yamaha head, block, internals, map sensor, etc... don't quite know about the throttle body size. I think all the throttle bodies are the same sizing on Gen III's (60mm), correct me if I'm mistaken.... tappet/rocker cover will be a different shape due to the water/air intercooler not being there. That's all I can think of for now... Rolling Eyes
Looking at dropping one in the Camry mate? Wink
Re: Gen3 3SGTE Differences Fri, 08 July 2005 06:07 Go to previous messageGo to next message
to take this a step further, what are the difference in gen3 when you go to ST215 adn St245?
i know the exhaust manifold and turbine housing are integrated, but can the exhaust manifolds be swapped between the series?
eg.
http://img47.auctions.yahoo.co.jp/users/1/2/4/0/patoric-img600x480-1117417573pic00002.jpg
RAV-GT4
Toymods member
Rydalmere, NSW
Re: Gen3 3SGTE Differences Fri, 08 July 2005 06:29 Go to previous messageGo to next message
I'm pretty sure the ST215 exhaust manifold is the same as the Gen II/III heads, but I'm not so sure about the ST245... isn't that a Gen IV 3S? Could be different bolt patterns... Confused
Re: Gen3 3SGTE Differences Fri, 08 July 2005 06:42 Go to previous messageGo to next message
ahh bugger.. appears to be a genIV in both St215 and 245... hmm, so any Gen1-3 manifolds don't bolt up huh? (the above one is for ST245...)
apologies for OT..
edit: oh.. maybe they are not gen IV.. stoopid Gen numbers Wink
it's some kind of engine Wink just ignore me...
[Updated on: Fri, 08 July 2005 07:00]
Joshstix
Toymods Vice President
Re: Gen3 3SGTE Differences Fri, 08 July 2005 06:52 Go to previous messageGo to next message
The 215 manifold will bolt up to the 205 head.
The 215 also has coil on plug ignition and OBD2 which would be nice.
Joshstix
Re: Gen3 3SGTE Differences Fri, 08 July 2005 06:54 Go to previous messageGo to next message
As to the original question the main difference I can think of is the computers are different, the 205 computer runs the water to air setup, and the water necks for the cooling system are different.
I am sure there are other differences but they are the ones I can think of. You'd be better off with the MR2 setup in a Camry in my opinion since you'd wanty a MR2 turbo gearbox for a front wheel drive conversion anyway.
Re: Gen3 3SGTE Differences Fri, 08 July 2005 07:19 Go to previous messageGo to next message
Joshstix wrote on Fri, 08 July 2005 16:52
Woot. Anyone got a picture of this setup? Do they fit the 205?
Puffy
Re: Gen3 3SGTE Differences Fri, 08 July 2005 07:20 Go to previous messageGo to next message
RAV-GT4 wrote on Fri, 08 July 2005 16:29
Hi Andrew
GenII and GenIII are different to each other so if it does fit, it would only fit one of those Gens.
Joshstix
Re: Gen3 3SGTE Differences Fri, 08 July 2005 08:08 Go to previous messageGo to next message
Cool1 wrote on Fri, 08 July 2005 17:19
I don't know about fitting the Gen 3 but here's a pic
http://img.photobucket.com/albums/v716/rusiankid/100_2507.jpg
I ganked this from http://www.mr2oc.com/showthread.php?t=118051&h ighlight=caldina
If you have a bit of a search around on MR2OC you should find some info on setting up a coil on plug system using a MSD DIS4 and Yamaha R600 coils I believe it was.
[Updated on: Fri, 08 July 2005 08:09]
Re: Gen3 3SGTE Differences Fri, 08 July 2005 09:47 Go to previous messageGo to next message
Joshstix wrote on Fri, 08 July 2005 18:08
That cam cover looks very simlar to the Gen3 so I dont see why the coils wont work. Obviously some holes will need to be drilled and tapped to hold the coils in, but this is no problem.
I'll check out that forum and see what I can find. Thanks mate
Draza
Wahroonga
Re: Gen3 3SGTE Differences Fri, 08 July 2005 13:11 Go to previous messageGo to next message
http://gtfour.supras.org.nz/3sgte%20table.htm
i like to use this page for comparing the gens. But it doesn't have the ST215 or ST245.
smashed_wombat
Re: Gen3 3SGTE Differences Fri, 08 July 2005 14:50 Go to previous messageGo to next message
Im fairly certain that a motor from an MR-2 will have the alternator, powersteer pump and possibly A/C compressors on the wrong side of the block for the Celica. For a less painful Camry swap I'd stick with a motor from a Celica. I haven't seen this myself, but it might be worth finding out if you're planning a conversion.
Re: Gen3 3SGTE Differences Sat, 09 July 2005 03:54 Go to previous messageGo to next message
smt_007 wrote on Fri, 08 July 2005 00:46
Cheers.
This will help you: http://gtfour.supras.org.nz/3S-GTE%20Conversion.ht m
smt_007
Re: Gen3 3SGTE Differences Sat, 09 July 2005 14:10 Go to previous message
Cool1 wrote on Sat, 09 July 2005 13:54
Cheers.
Nice find Cool, thanks for the info guys Very Happy.
[Updated on: Sat, 09 July 2005 14:10]
Previous Topic:New here, Dont know what type motoer I have, But would like some home conversions - giddy up
Next Topic:4AGE and 4AGZE Ignition Setups
Current Time: Fri Oct 23 04:04:59 UTC 2026
Total time taken to generate the page: 0.0055718421936035 seconds
