Toymods » Tech & Conversions » Replacement of inlet cam only
corbet01
April 2005
Replacement of inlet cam only Fri, 08 July 2005 09:17 Go to next message
HI,
Will i get a decent power gain by replacing the inlet cam, say 264 on a small port 100kw engine? Are the exhaust and inlet interchangable?
Big T
Re: Replacement of inlet cam only Fri, 08 July 2005 09:45 Go to previous messageGo to next message
NO the inlet cannot be interchanged with the exhaust cam. The exhaust cam has a gear to drive the dissy as shown here.
http://img101.echo.cx/img101/7876/parts0262aj.th.jpg
corbet01
April 2005
Re: Replacement of inlet cam only Sun, 10 July 2005 05:06 Go to previous messageGo to next message
I read some where that when you buy 4age cams to buy 2 exhaust ones which i figured that the the exhaust could go into the inlet.
The reason i am asking is because i am thinking of buying one cam of 254 or 264 and putting into tyhe inlet and at a later date buying a 272 or some thing and swappig the 254/264 to the exhaust.
feral4mr2
Bundaberg, Qld.
Re: Replacement of inlet cam only Sun, 10 July 2005 08:08 Go to previous messageGo to next message
by memory an exhaust cam will fit on the inlet side with the distributor drive gear. it has been a while since i played with my dismantled engine, but i am sure i tried it out and it worked.
Big T
Re: Replacement of inlet cam only Sun, 10 July 2005 08:11 Go to previous messageGo to next message
Yeah that's fair enough then. I thought you were asking of you can put an Inlet cam into the Exhaust side! I don't know for certain if it would work but i don't see any reason it shouldn't.
corbet01
April 2005
Re: Replacement of inlet cam only Sun, 10 July 2005 10:32 Go to previous message
Thanks for the help.
is there anyone out there that has tried just one cam
Previous Topic:22RE Gearbox Odd problem ? ****************
Next Topic:MA70 - 1JZ heater problem
Current Time: Tue Oct 20 06:33:42 UTC 2026
Total time taken to generate the page: 0.0048298835754395 seconds
