Toymods » Tech & Conversions » ma70/jza70 axle tramp
RAWS
Adelaide Street Racing ca...
ma70/jza70 axle tramp Fri, 08 July 2005 11:32 Go to next message
Hi all,
My 89 ma70 (stock suspension) has axle tramp when dropping the clutch. The 1jz is in the process of being installed which I can imagine is only going to aggravate this problem further. Is this just a case of worn out rear shocks or does this model have a problem with axle tramp?
Also, it has a standard diff. Would this be a torsen LSD and are they any good? The car is on a rapid path to high horsepower and im wondering if I will need to get an OS Giken superlock or something similar.
V8_MA61
Re: ma70/jza70 axle tramp Fri, 08 July 2005 11:39 Go to previous messageGo to next message
ma70s have clutch type lsds
Its VERY strange you have axle tramp...the shocks must be absolutely shagged.
Ive been in some hi-powered ma70s with stock suspension, and they have been a joy to ride in, no tramp whatsoever. Have it checked over by a shop, it doesnt sound too good.
V8_MA61
Re: ma70/jza70 axle tramp Fri, 08 July 2005 11:42 Go to previous messageGo to next message
also, no you wont have to replace it due to more power from the 1jz. A lesser powered 7mgte would probly do more damage due to torque factor.
Ive seen ma70s with stock diffs pull 350rwkw without dramas. Run good oil, and maintain it like you would a motor, and it will last. i use penrite limslip
BlackSupra
Re: ma70/jza70 axle tramp Sat, 09 July 2005 01:01 Go to previous messageGo to next message
Yeah stuffed rear suspension, fix it before you go 1jz.
RAWS
Re: ma70/jza70 axle tramp Sat, 09 July 2005 06:14 Go to previous message
thanks guys, buying bilsteins shortly (Unless my offer to buy the HKS T3G's is accepted.... That'll delay the susp a little bit. Smile
Previous Topic:2tgeu spluttering at revs
Next Topic:Gear used for Dyno run?
Current Time: Sun Oct 25 20:50:09 UTC 2026
Total time taken to generate the page: 0.033056020736694 seconds
