Toymods » Tech & Conversions » ra23 rear window rollers
kristianvanek
Gatton, Queensland
ra23 rear window rollers Sat, 09 July 2005 01:21 Go to next message
just need some help in fixing the common problem that we all get with celica's. just need some help in finding something to use to replace the rollers. been to all of my local hardwares and i cant get anything to do the job. everything is just to different and cant mod to fix. please help
riceburna73
Re: ra23 rear window rollers Sat, 09 July 2005 02:27 Go to previous messageGo to next message
Hey mate there was a really good post on this subject some time ago so try a search..
If unlucky with that,
Go to bunnings and get a 25mm roller,they are originally for sliding doors I believe,the one your after has green cardboard insert and is in a glad type resealable bag..It comes with the roller and a nylon lock nut..Hope that describes it for you..After you get it take the back windows out you should be able to manouver the regulator to pop out the top exposing the two metal pins the old shitty rollers used to be attached to.When they are out far enough from the window get an angle grinder and cut the fokkers off. After you have done this just push the remaining bit of pin through,you may need a punch,this will leave a perfect hole as the pins were originally just pressed into the regulator.Get your new roller ad attach,I didnt use the nylon nut as i just couldnt do it up without the roller spinning aswell so I just used a normal nut and spring washer..i think from memory all i needed to undoo on the regulator was the 4 bolts around the winder to get it up to enough to work on,mind you I hadnt sprayed the car at that stage so using and angle grinder near the shitty interior/body didnt worry me soo much,so you may want to take the whole thing out if you do just dont move the channeling in any way to save time on having to adjust the whole thing again..The end result is worth the time as they are just a dream to use after with no play..
Good luck
kristianvanek
Gatton, Queensland
Re: ra23 rear window rollers Sat, 09 July 2005 02:40 Go to previous messageGo to next message
yeah i will have to see if i can get to a bunnings to see if i can find these rollers. any chance that u can get them for me so as i am not getting the wrong ones??? i will pay u the right price. only have to fix the passenger side window. i already have the window channels and stuff out already ready to fix it all up. and so if i have this right all i need to do is remove the pins out off of the window regulator and then put the new rollers on then put it all back together.
mini&ta22fan
Penrith
June 2005
Re: ra23 rear window rollers Wed, 13 July 2005 07:15 Go to previous messageGo to next message
I used Ht monaro rollers on mine i had to file them a bit thinner
then all i did was drill out the posts and add the new ones peening over the end soo they didnt move, they were a rare spare
product i kept the packet if your intrested in the product number or havent fixed it the other way yet
kristianvanek
Gatton, Queensland
Re: ra23 rear window rollers Wed, 13 July 2005 08:28 Go to previous message
yeah i am going to look around but basically i need to take the original pins off the track and put new ones in.
Previous Topic:How to fit Driving and Fog Light to a 1991 SX Seca 5 speed
Next Topic:LSD Gear Oil
Current Time: Fri Nov 20 21:52:00 UTC 2026
Total time taken to generate the page: 0.20289993286133 seconds
