Toymods » Tech & Conversions » 4agte with 20v head
Rukas
Blacktown
June 2005
4agte with 20v head Sat, 09 July 2005 03:17 Go to next message
hey all
i just bought my self a 4agte import..
At the moment i have a silvertop 20v.
i no this has been asked a million times but i stil wanna get the perfect answer Wink
OK i wanna put my 20v head onto my gze block.
How can i keep my quad throttle body's???
how do i work out how big my custom plemem chamber should be?
If i bolt my 20v head onto the gze block without no work done to it will it be ok?
SO can we also answer this question
I bolt my 20v head on the gze block, get custom plenum chamber and hook it all up Will it run??? if yes how good if no what mods should i do to my head to make it better...
Sorry for the questions..
Thanks Wink
4agte
Toronto, Downtown
Re: 4agte with 20v head Sat, 09 July 2005 03:41 Go to previous messageGo to next message
using the search button would help....
other than that i didnt know there was a 4agte import i think you mean 4agze...
I belive there is issues with using the 20v head on the gze bottom end as there may be issues with the valve recesses in the piston
if you put the 20v head on the gze you will definatley be able to use the quads.
why bother with a custom plenium when you could just use the 20v one..
Rukas
Blacktown
June 2005
Re: 4agte with 20v head Sat, 09 July 2005 04:00 Go to previous messageGo to next message
hey
yeh it has been converted to turbo Wink
nah ive read alot about the recesses in the pistons there only there to prevent damage if ya timeing belt breaks..
The reason im thinkning of custom plenum chamber is with turbo you need more room and speed velocity for the boost...
And i dont think the plenum chamber on the 20v is a seal unit..
Im not sure though so yeh...
4agte
Toronto, Downtown
Re: 4agte with 20v head Sat, 09 July 2005 06:56 Go to previous messageGo to next message
Rukas wrote on Sat, 09 July 2005 14:00
hey
i dont know about you but to me thats a good thing it keeps the motor non interference if the belt breaks you might well end up having to replace the head and a few pistons
Rukas
Blacktown
June 2005
Re: 4agte with 20v head Sat, 09 July 2005 07:19 Go to previous messageGo to next message
yeh i no its better but with the 29v head more air flow and that...
negative boost
Hobart, TAS
Re: 4agte with 20v head Sat, 09 July 2005 11:57 Go to previous messageGo to next message
Just an idea but you could buy some 20v pistons to use with the 20v head if your concerned about interference? Not sure if it work but its an idea
Gwaijaitat
April 2005
Re: 4agte with 20v head Sat, 09 July 2005 13:07 Go to previous messageGo to next message
The 16v piston won't hit the 20v head's valves, they'r non interference type head. But the 16v pistons don't hv the cut-outs in the right place for the 20v head's valves , so using 16v gze piston with 20v head may make worse combusion than using the gze piston with 16v head. Let's go get some 7.5:1 forged pistons for 20v head and boost it to 20psi!!
[Updated on: Sat, 09 July 2005 13:10]
Rukas
Blacktown
June 2005
Re: 4agte with 20v head Sat, 09 July 2005 23:34 Go to previous message
hehe sounds good
are all the gze bores the same size???
Does any 1 know of any 1 who can get low compression 20v pistons that will go on gze rods???
Previous Topic:3tc dizzy point wanna make it electronic
Next Topic:3SGE and AE82/92
Current Time: Thu Nov 19 11:21:52 UTC 2026
Total time taken to generate the page: 0.0085868835449219 seconds
